Rear fan - Cabby - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Rear fan - Cabby (/showthread.php?tid=32467) |
Rear fan - Cabby - insomaniac45 - 08-11-2015 Hey guys, for those in the know, does the rear window fan unit on the cabby supply heat? or is it just to blow air? only it never seems to clear the window of condensation...... its about as much use as a chocolate fire guard RE: Rear fan - Cabby - puggered - 22-11-2015 While you've probably worked it out by now, They have a heating element wire in the housing that provides p*ss poor heat. They work just like a hairdryer which seems surprisingly appropriate. RE: Rear fan - Cabby - insomaniac45 - 03-12-2015 So there should be some heat there. Not alot, but some........ which could be why it takes forever to clear. I will have to check just how much heat is coming out. As i am using the car through winter, and a clear rear window would be helpful Thanks puggered. |
