WARING RUST! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: WARING RUST! (/showthread.php?tid=32437) |
WARING RUST! - tysonbully2k12 - 05-11-2015 ![]() ![]() ![]() ![]()
RE: WARING RUST! - bashbarnard - 05-11-2015 Side skirts are sods for this on these. Thats why i refuse to fit them to mine. Its unfortunate but common now. RE: WARING RUST! - tysonbully2k12 - 05-11-2015 (05-11-2015, 02:37 PM)bashbarnard Wrote: Side skirts are sods for this on these. Thats why i refuse to fit them to mine. Its unfortunate but common now. whoever had the car before me loved wood screws and tex screws there EVERYWHERE the hole is worse now ive been poking at it
RE: WARING RUST! - welshpug - 05-11-2015 pugplus car? RE: WARING RUST! - tysonbully2k12 - 05-11-2015 (05-11-2015, 02:40 PM)welshpug Wrote: pugplus car? have no idea what that means
RE: WARING RUST! - HDi--Power - 05-11-2015 Pugplus is a questionable Peugeot parts dealer, but given its an Irish car it cant have come from him. Time to get the welder out RE: WARING RUST! - Eeyore - 05-11-2015 What? filling holes with expanding foam isnt a solution? D: RE: WARING RUST! - insomaniac45 - 06-11-2015 (05-11-2015, 06:54 PM)Eeyore Wrote: What? filling holes with expanding foam isnt a solution? D: i thought it was newspaper and filler........ i mean, who has the time to cut out all the old rotten stuff, and weld good metal back in
RE: WARING RUST! - ozonehostile - 06-11-2015 Looks like the hole I repaired on my 6,seem to be caused by mongs jacking the car off the hollow sill on metal less than 1mm thick, cracks, water gets in then rots the sill from the inside out all hidden by the skirt. Matts rallye was the same too RE: WARING RUST! - Paul Baldwin - 06-11-2015 (06-11-2015, 09:47 AM)insomaniac45 Wrote:(05-11-2015, 06:54 PM)Eeyore Wrote: What? filling holes with expanding foam isnt a solution? D: Newspaper and filler is old skool nowadays! A friend bought a car a while back, it took a couple of years to show up but a large "repair" with expanding foam and filler showed itself in the end. Nothing really changes when it comes to bodging! RE: WARING RUST! - Toms306 - 06-11-2015 (06-11-2015, 09:47 AM)insomaniac45 Wrote:(05-11-2015, 06:54 PM)Eeyore Wrote: What? filling holes with expanding foam isnt a solution? D: Someone had 'fixed' the chassis rails like that on a HDi I bought last year!
RE: WARING RUST! - Paul Baldwin - 06-11-2015 Look at the plus sides, it's lighter and if you do like Dum-Dum did it'll float itself out of trouble
RE: WARING RUST! - karl1989 - 06-11-2015 Look at my old progress thread of my ph1. That had rust RE: WARING RUST! - insomaniac45 - 07-11-2015 (06-11-2015, 06:17 PM)Paul Baldwin Wrote: Look at the plus sides, it's lighter and if you do like Dum-Dum did it'll float itself out of trouble lol. instead of the toyboata from top gear, it could the pugboat.... fill it all with expanding foam, and stick an outboard on it... RE: WARING RUST! - Rippthrough - 07-11-2015 (05-11-2015, 02:37 PM)bashbarnard Wrote: Side skirts are sods for this on these. Thats why i refuse to fit them to mine. Its unfortunate but common now. They go there even without side skirts, it's just most cars are only just getting to the age where it shows, as unfortunately it goes from the inside out. Expect to see a lot more similar in the next few years! RE: WARING RUST! - Matt - 08-11-2015 Too g to be checking mine out now! Scares the crap out of me RE: WARING RUST! - tysonbully2k12 - 16-11-2015 Peugeot RE: WARING RUST! - Ben_w - 16-11-2015 Fibreglassed??????? RE: WARING RUST! - Redordead89 - 16-11-2015 By no heater do you mean no power to fan so switch does nowt or no heat from blower when on? RE: WARING RUST! - Toms306 - 16-11-2015 Should've scrapped it before fixing rust tbh, sounds like a heap. Now you've put time and money into that, only way you'll get it back is to fix and sell now. RE: WARING RUST! - Rippthrough - 16-11-2015 (16-11-2015, 07:26 PM)Ben_w Wrote: Fibreglassed??????? I.E - Bodged it! ![]() Still, not to worry, it's only one of the main structural bits in the car... RE: WARING RUST! - Ben_w - 16-11-2015 (16-11-2015, 08:24 PM)Rippthrough Wrote:(16-11-2015, 07:26 PM)Ben_w Wrote: Fibreglassed??????? That was my worry...... All the rust ony Rallye number two got cut out and we used chassis and sill cuts from a scrapper to repair... RE: WARING RUST! - Rippthrough - 16-11-2015 I think the sill repair on mine will still be there after the car has dissolved in the rain tbfh. RE: WARING RUST! - Eeyore - 16-11-2015 is the title of this meant to be warning rust or waring rust? RE: WARING RUST! - pugtk - 17-11-2015 Looks like a typical D-turbo ![]() Usually bodged together RE: WARING RUST! - meridianman - 17-11-2015 What did you decide; scrap or repair? |
