Cabriolet hdi conversion - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Cabriolet hdi conversion (/showthread.php?tid=32335) |
Cabriolet hdi conversion - aggyj17 - 24-10-2015 Right I am going to do a hdi conversion in the Mrs cabriolet it's a late phase 3 (52 plate) 1.8 and I have a phase 3 hdi(y reg) with multiplex 3 pin ecu. If I use the whole engine bay loom with the bsi and the chip would it all be a case of plug and play? Or is it easier to use a single plug loom and ecu. RE: Cabriolet hdi conversion - Chris1357 - 25-10-2015 Me & a member of .Net done it a few years ago.. It's as simple as plugging the loom in yes! We had to change a whole hoast of things including Fuel lines Hdi ones are longer IIRC Clocks Fuel cooler under chassis Exhaust we had to mock up using Hdi-1.8 IMO it's such an easy conversion Chris |
