Key won't turn... - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Key won't turn... (/showthread.php?tid=32246) |
Key won't turn... - connorp - 16-10-2015 Hi my key won't turn so I obviously can't start my car, I was driving it no more than 25 minutes ago and have been trying for the past 15 mins to turn it and it's no working, the steering lock is on and it won't come off, how can I overcome this issue? and yes I have tried turning the wheel and turning the key like you normally would to release the steering lock RE: Key won't turn... - Poodle - 16-10-2015 Tried a bit of lube? RE: Key won't turn... - Paul_13 - 16-10-2015 Don't use wd40! RE: Key won't turn... - Ben_w - 16-10-2015 Plenty of wiggling the key and wiggling the steering wheel at the same time. It should hopefully eventually come free. If it does, not not remove the key until you have a replacement lock to go in. Likely the mech is worn hence the steering lock won't release. Almost certain you need to have the steering lock unlocked to change the barrel RE: Key won't turn... - daveylennon93 - 16-10-2015 Had to change the barrell in mine the other day because lost my keys. Just made shit of the bits that lock the barrel in place with a hammer and punch. It slid straight out thenâș RE: Key won't turn... - C2K - 17-10-2015 I had this with my hdi. Quick bit of lube and it never happened again. RE: Key won't turn... - Redordead89 - 17-10-2015 Graphite lock lube FTW! Key won't turn... - connorp - 19-10-2015 I managed to get it free with wiggling of both parts, it has only done it 3 times in the 10 months I have owned the car and doesn't do it very often so I will wait until it fully goes and then lube it up
RE: Key won't turn... - Toms306 - 19-10-2015 When it fully goes it'll be beyond lubing... Not fun if you're stuck miles away somewhere... RE: Key won't turn... - Redordead89 - 19-10-2015 (19-10-2015, 11:02 AM)Toms306 Wrote: When it fully goes it'll be beyond lubing... Not fun if you're stuck miles away somewhere...Yup +1 go get graphite lock lube and give it a squirt while you still can! It's only a fiver and will save you time and money later! RE: Key won't turn... - Mattcheese31 - 19-10-2015 Don't spray wd40 in it, you need graphite power as said
Key won't turn... - connorp - 19-10-2015 So where do I spray it? Presumably inside the barrel? RE: Key won't turn... - Redordead89 - 19-10-2015 Yes Connor, if you put the key in a little bit say 10mm and use the edge of the key to squirt it against two or three times then it will trickle in to the barrel then while your key is still coated run it in and out of the barrel a few times to coat all pins and levers! Once you've done this do your door and tailgate barrels even if you usually use the key button to unlock the car! Key won't turn... - connorp - 20-10-2015 (19-10-2015, 07:34 PM)Redordead89 Wrote: Yes Connor, if you put the key in a little bit say 10mm and use the edge of the key to squirt it against two or three times then it will trickle in to the barrel then while your key is still coated run it in and out of the barrel a few times to coat all pins and levers! Once you've done this do your door and tailgate barrels even if you usually use the key button to unlock the car! Thanks a lot man, I will get some on the order
RE: Key won't turn... - Redordead89 - 20-10-2015 The brand I use is Ambersil. Key won't turn... - connorp - 13-11-2015 I used aerosol silicone lubricant and it hasn't happened since, cheers everyone RE: Key won't turn... - Redordead89 - 14-11-2015 Awesome! Now go get some graphite lock lube and do it properly so it defo doesn't happen again, I am a fan of silicone based spray lube btw but when it comes to door locks or barrels go graphite every time! RE: Key won't turn... - meridianman - 15-11-2015 +1 for the Graphite - had a nightmare with my Passat before using it and now it slides in like a hot knife in butter RE: Key won't turn... - bashbarnard - 15-11-2015 If anyone knows where to buy graphite from the info would be great RE: Key won't turn... - Redordead89 - 15-11-2015 (15-11-2015, 09:29 AM)bashbarnard Wrote: If anyone knows where to buy graphite from the info would be great http://www.ebay.co.uk/itm/Pack-of-3-AMBERSIL-Graphite-Padlock-Lock-Lube-Long-Lasting-Lubrication-/391319597055?hash=item5b1c772fff:g:shsAAOSwgQ9VgTu8 Should always be carrying a 3 pack anyway lol! |
