Help: 2.2 hdi 4hx + BE4 gearbox possible? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Help: 2.2 hdi 4hx + BE4 gearbox possible? (/showthread.php?tid=32216) |
Help: 2.2 hdi 4hx + BE4 gearbox possible? - bixigu - 13-10-2015 Hi all, im from spain, and im new here. First i want to say sorry for my poor english. I have many 2.0 hdi cars at home (berlingo, 306, and two 206). One of 206 its a track/rally 206 with 2.0 hdi engine: 2.0 90hp RHY engine with cummins nozzles (8 holes), r75 iveco pump, gtb2056v from alfa romeo brera, torsen diff, ... . But im thinking on bigger engine: I have bought 4hx 2.2 hdi engine from c5 with ml5 gearbox , but when i try to fit be4 gearbox... dont fit! very different body Does anyone know what I can do to fit be4 gearbox in dw12 block? Is this posible? RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - welshpug - 14-10-2015 there are many be4 bellhousings, have you got the right one? RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - Poodle - 14-10-2015 Hi, welcome, your English is fine. Do you have a project thread for the 206? Sorry i haven't got anything useful to add. RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - bashbarnard - 14-10-2015 (14-10-2015, 05:31 AM)Poodle Wrote: Hi, welcome, your English is fine. Do you have a project thread for the 206? Sorry i haven't got anything useful to add. What he said. Project thread for the 206 would be epic RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - Piggy - 14-10-2015 Afail the 'be' boxes wont fit the 2.2 blocks. Sorry. Also the engine mounts/extra weight be a bit of a biatch I'd suggest 16v head on your current 8v block
RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - bixigu - 14-10-2015 (14-10-2015, 07:12 AM)Piggy Wrote: Afail the 'be' boxes wont fit the 2.2 blocks. Sorry. I have here rhw entire engine (not in good condition), but i preffer to use 2.2 4hx, because this engine have only 100.000km. But i dont want to remake transimissions, supports, ... much work I have to reconsider again perfect engine for my 206... To make good setup I have 2 rhy engines, rhw engine , and 4hx engine. What's the best combination to make best 2.0 16v engine? 4hx discarted. RE: Help: 2.2 hdi 4hx + BE4 gearbox possible? - Ruan - 14-10-2015 2.2 4HX and 2.0 RHW heads are the same (look on the back of the head, there's V35 and V40 casting marks - both are used on 4HX and RHW) - injectors are different though. Use RHW pistons in RHY block and 4HX or RHW head. There's a guy on here - Dashmader who has done this (4HX head on RHY block), although he used RHR pistons which have a different combustion chamber and require sightly different injectors. |
