aux spring tensioner change help! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: aux spring tensioner change help! (/showthread.php?tid=32074) |
aux spring tensioner change help! - simonson1982 - 30-09-2015 I need to change the spring tensioner on the aux belt this weekend. Any advice or tips when doing this? RE: aux spring tensioner change help! - Piggy - 30-09-2015 Depends which one.. Early xud9 is dead simple, couple bolts and jobs a gooden... Later one is a pig! RE: aux spring tensioner change help! - simonson1982 - 30-09-2015 That's the bugger RE: aux spring tensioner change help! - Piggy - 30-09-2015 Oooh thats a biatch RE: aux spring tensioner change help! - simonson1982 - 30-09-2015 Never done it before...any advice? I know I'll have to remove the engine mounts and lower the engine buts thats about as far as I've thought! Cheers RE: aux spring tensioner change help! - Seb_Ryan - 30-09-2015 Power steering pump off, alternator off, and something else..been years since i done mine but its a twat lol the spring is a right arse wipe RE: aux spring tensioner change help! - Piggy - 30-09-2015 Just top end mount. Jack with block of wood under sump Remove inner arch liner. PAS pump off. Then fiddle. A lot. RE: aux spring tensioner change help! - simonson1982 - 01-10-2015 Ok cheers for the help |
