95 degrees 110 hdi 307 not good :-( - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 95 degrees 110 hdi 307 not good :-( (/showthread.php?tid=31755) |
95 degrees 110 hdi 307 not good :-( - Redordead89 - 30-08-2015 Battery about to die on phone :-( Feels paper based not oily! RE: 95 degrees 110 hdi 307 not good :-( - ADV_93 - 30-08-2015 Bless Are your fans coming on? RE: 95 degrees 110 hdi 307 not good :-( - Poodle - 30-08-2015 Paper-based eh? Interesting... ![]() Any background info, what was happening at the time, has it happened before, pressurised coolant pipes, etc? RE: 95 degrees 110 hdi 307 not good :-( - bashbarnard - 30-08-2015 Thats stop leak in there. Car new to you?? Re: RE: 95 degrees 110 hdi 307 not good :-( - Seb_Ryan - 30-08-2015 (30-08-2015, 05:50 PM)bashbarnard Wrote: Thats stop leak in there. Car new to you?? This.. Rad weld or simular RE: 95 degrees 110 hdi 307 not good :-( - Redordead89 - 30-08-2015 Had it for 5 months -7500 miles so far, heater matrix needs done as I can smell coolant inside when I use heaters and a little steam on window occasionally, if not head gasket material and it is stop leak or similar then maybe previous keeper tried to seal the matrix with it??? So so glad I have the 306 too! RE: 95 degrees 110 hdi 307 not good :-( - bashbarnard - 30-08-2015 Sounds like it man. Seen it many times. Small leak. Lets bung some rad weld in and sell it. RE: 95 degrees 110 hdi 307 not good :-( - Redordead89 - 30-08-2015 Really hope it is the matrix cos I've got a good one in the boot from a 55 plate xsi Hdi! Will fit the new matrix and flush the system in the next few days but still it doesn't explain the 94-95 degree temp? I'm on my fifth Hdi and never seen one that hot! RE: 95 degrees 110 hdi 307 not good :-( - bashbarnard - 30-08-2015 could just be causing an air lock. so yes could explain the temp RE: 95 degrees 110 hdi 307 not good :-( - Redordead89 - 30-08-2015 (30-08-2015, 07:46 PM)bashbarnard Wrote: could just be causing an air lock. so yes could explain the temp Hi Bash, just talking with my bro on the possibility of said stop leak having let go from the matrix and poss be causing a blockage so going to back flush the system before I refit the matrix! I will flush in to a bucket and see what's in there! Hopefully get it all out! Onlyl plus to this happening is I get to drive only the 306 til it's fixed! ;-) RE: 95 degrees 110 hdi 307 not good :-( - bashbarnard - 30-08-2015 could easily cause a blockage. i hate the stuff. I would connect the pipes from the matrix together fill with water and a dishwasher tablet run it to temp then drop the coolant. after that bang the new matrix in job done RE: 95 degrees 110 hdi 307 not good :-( - cully - 30-08-2015 Crush the tablet up first though
RE: 95 degrees 110 hdi 307 not good :-( - Mattcheese31 - 30-08-2015 That's 93 degrees but still too hot for a hdi, deffo flush system the from from there
RE: 95 degrees 110 hdi 307 not good :-( - Redordead89 - 30-08-2015 (30-08-2015, 09:50 PM)Mattcheese31 Wrote: That's 93 degrees but still too hot for a hdi, deffo flush system the from from there Hi Matt, it climbed another couple of degrees before I got stopped but oddly it stayed around 84-86 all the way home, I did a 11 hour shift in dominos yesterday with it and had ran it in 4th at 70 on the way to work yesterday morning to try clear out dpf! On the way home I had a bit more steam on the screen than usual ( only happened occasionaly ) and just been putting off fitting the new matrix! Push has came to shove so when I get it off I'll take some pics of the job and post it up! (30-08-2015, 05:05 PM)ADV_93 Wrote: BlessWill check tomorrow as when I got home I had to go right back out so jumped in the 306 and blanked the SW for the night! RE: 95 degrees 110 hdi 307 not good :-( - Mattcheese31 - 30-08-2015 Steam on screen, change matrix lol, deffo needs doing, probs not bled properly won't help temps RE: 95 degrees 110 hdi 307 not good :-( - Redordead89 - 15-09-2015 Fun fun fun |
