Please Help! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Please Help! (/showthread.php?tid=31730) |
Please Help! - Nathan1305 - 28-08-2015 trying to do the cambelt on the 306 and failing horribly. I need an impact gun to get the crank bolt off. Is anyone close enough to Bristol to give me a hand sometime? Doesn't have to be today RE: Please Help! - Toms306 - 28-08-2015 Have you not got a long bar and a missus? Ask her to hold the brake while you undo the pulley bolt with a long extension. Or people will tell you to flick the starter if you're feeling brave lol... RE: Please Help! - Nathan1305 - 28-08-2015 (28-08-2015, 03:15 PM)Toms306 Wrote: Have you not got a long bar and a missus? Ask her to hold the brake while you undo the pulley bolt with a long extension. Can't get the car high enough to get a bar underneath. Plus if someone stands on the brakes the crank still turns :/ Re: RE: Please Help! - Seb_Ryan - 28-08-2015 (28-08-2015, 04:27 PM)Nathan1305 Wrote:(28-08-2015, 03:15 PM)Toms306 Wrote: Have you not got a long bar and a missus? Ask her to hold the brake while you undo the pulley bolt with a long extension. Put it in 4th gear lol RE: Please Help! - titch - 28-08-2015 Yeah i had to put mine in a high gearand someone on the brakes and then i had a breaker bar on it with about 5ft of scaffold pole on the breaker bar and it eventually went, i thought i was going to break something ! RE: Please Help! - Nathan1305 - 28-08-2015 (28-08-2015, 04:35 PM)Seb_Ryan Wrote:(28-08-2015, 04:27 PM)Nathan1305 Wrote:(28-08-2015, 03:15 PM)Toms306 Wrote: Have you not got a long bar and a missus? Ask her to hold the brake while you undo the pulley bolt with a long extension. I put it in 5th and still turned guessing it has to be 4th? RE: Please Help! - tigerstyle - 28-08-2015 + harder on the brakes? It sounds like you've got it jacked up too maybe? Let it back down to the ground if so... RE: Please Help! - Jonny81191 - 28-08-2015 Put a bar on it and flick the starter, it's not the best method but it certainly works. RE: Please Help! - bashbarnard - 28-08-2015 (28-08-2015, 04:53 PM)Jonny81191 Wrote: Put a bar on it and flick the starter, it's not the best method but it certainly works. This. Pikey FTW. Disconnect something to make it not start though. Eg stop solinoid. RE: Please Help! - Piggy - 29-08-2015 Yup, as above. Had to resort to this once or twice RE: Please Help! - Ruan - 31-08-2015 If it's turning, sounds like you've not got wheel bolts in and no disc locators - you need wheel bolts in to stop the disc spinning vs the hub. RE: Please Help! - toseland - 02-09-2015 i second the pikey method.. i would, if possible, jam the breaker against the floor if possible though, to stop it tearing holes in a bulkhead or otherwise. starter has a ncie amount of torque |
