rev counter - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: rev counter (/showthread.php?tid=31695) |
rev counter - vinny - 24-08-2015 ive just put a gti6 flywheel on a 306 19 td and used a xantia 19 td sensor in top of gearbox it plugged straight in loom as jack plug the same but when started it shows flat out at 6k any ideas ? RE: rev counter - bashbarnard - 24-08-2015 Probally the wrong sensing system to work with yours. Why put a gti6 one on? Apart from its slightly lighter RE: rev counter - vinny - 24-08-2015 the ring gear was f*cked i had a spare gti6 one so fitted that with a new clutch as needed both feet to press the clutch the rev counter didnt work at all before i put a 19 td in a 1.4 once and th counter worked on the original clocks ok so dont think clocks any diffferent |
