Fan relay specs on a hdi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: Fan relay specs on a hdi (/showthread.php?tid=31692) |
Fan relay specs on a hdi - mattbarker32 - 24-08-2015 Does anyone know what the specs are of the fan relays on the hdi i think their 12v 5 pin 35v. Does it have to be 35v as I have got 30v and 40v relays thinking of using the 40v relays but not sure of the electrical draw on them. Anyone have a idea. Sorry ment amps not volts auto correct on new phone arrrh RE: Fan relay specs on a hdi - cully - 24-08-2015 the 30 35 40 is the current rating check again i think you will see it is a *A* not a *V* if you replace a relay replace it with one the same colour you should be ok then
RE: Fan relay specs on a hdi - mattbarker32 - 24-08-2015 Cheers realise after i posted it that my phone had done a auto correct on the post. Thanks will look for some |
