6 speed gearbox conversion - Printable Version
+-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38)
+--- Forum: Projects (https://www.306oc.co.uk/forum/forumdisplay.php?fid=39)
+--- Thread: 6 speed gearbox conversion (/showthread.php?tid=31671)
6 speed gearbox conversion - littlerhino - 22-08-2015
I've been offered a 6 speed box to go onto my xsi can anybody tell me if it's a straight swap apart from the reverse gear lift cable ?
RE: 6 speed gearbox conversion - xudlingo - 22-08-2015
Will bolt on say by by to turning circle lol
RE: 6 speed gearbox conversion - littlerhino - 22-08-2015
Why would it alter your turning circle the steering is the same ?
RE: 6 speed gearbox conversion - Lwilliams - 22-08-2015
The extra gear on the end will hit your tyre preventing you from full lock right
Right ok cheers
RE: 6 speed gearbox conversion - maxzy - 22-08-2015
Directly fit, just a little bit right turning radius.
If you didn't have the reverse cable after 6 mt installed, The car can be temporary drive without the cable but just beware the shifting from 4th to 5th and when 5th to 6th, reverse can be selected by pull to the right side of 6th.
RE: 6 speed gearbox conversion - littlerhino - 24-08-2015
What if you put wheel spacers on the front would that solve the wheel lock issue ?
RE: 6 speed gearbox conversion - welshpug - 24-08-2015
not really, as you'd mess up your steering angles and foul the wheelarches instead
