What cambelt? - Printable Version
+--- Thread: What cambelt? (/showthread.php?tid=31519)
What cambelt? - Nathan1305 - 07-08-2015
Looking at cambelt kits and the choices are INA and Dayco. Is one better than the other or are they pretty much the same? Also is it worth just doing the belt or all the tensioners and water pump at the same time?
RE: What cambelt? - r3k1355 - 07-08-2015
Yes do all the tensioners, belts and the waterpump at the same time.
Dayco are a decent make, can't go far wrong with them.
Make sure you get a decent waterpump as well, one with metal impellers not the plastic ones.
RE: What cambelt? - welshpug - 07-08-2015
dayco is o.e for pugs, INA make the tensioners in Dayco kits, INA kits tend to have dayco belts in them.
RE: What cambelt? - bashbarnard - 07-08-2015
Ive always used gates on mine. Admittedly my 2.1 currently has an old stock genuine item on that cost me £20. Sometimes i love ebay
What cambelt? - Frosty - 07-08-2015
Dayco be fine, check the tensioners for play but they are usually fine to go again on these engines. Be worth doing the water pump though
RE: What cambelt? - mr_fish - 07-08-2015
Acquired a PSA Genuine belt kit, has Dayco belt in as said above.
RE: What cambelt? - lolsteve - 07-08-2015
Dayco has fixed my belt whine. Unipart was crap
RE: What cambelt? - MrBigMac - 07-08-2015
i run Gates and a decent water pump
