Pipercross or K&N - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Pipercross or K&N (/showthread.php?tid=31016) |
Pipercross or K&N - RetroPug - 28-06-2015 Which sounds better? K&N gauze cone filter or a Pipercross foam one? This is for a GTi6 engine. I've tried K&N many times but never run a PiperX one. RE: Pipercross or K&N - Stef205 - 28-06-2015 Foam everytime or if you have some cash a itg filter imo plus when it's upside down it reads gti
RE: Pipercross or K&N - impotentials - 28-06-2015 Had pipercross, have kn 57i now. Go piper for induction noise. RE: Pipercross or K&N - miles - 28-06-2015 Ram Air, better and cheaper too RE: Pipercross or K&N - Toms306 - 28-06-2015 I had a Ram Air one...noise was awesome.
RE: Pipercross or K&N - 7057sam - 28-06-2015 My k&n sounds way better than the viper I had on the rallye RE: Pipercross or K&N - lolsteve - 29-06-2015 My K&N Apollo sounds a bit vtec-y when hooning but doesnt seem much louder than stock when part throttle driving RE: Pipercross or K&N - RetroPug - 29-06-2015 To clarify: I've got a K&N open cone that sounds pretty good and I've found a PiperX one in a cupboard that I was wondering whether or not to bother trying it out. If foam does sound noticeably different or better I might give it go. Thanks. RE: Pipercross or K&N - Pebbles167 - 29-06-2015 Wire gauze, no air filter! BWAAAAAARP!! But seriously, I've found that all cones make a pretty good grunting noise. I'm currently using a K&N cone, but I used a cheapo metal one on my 106 gti and made a good noise aswell. RE: Pipercross or K&N - lolsteve - 29-06-2015 http://www.fastcar.co.uk/2012/05/04/performance-car-air-filter-test/9/ k&n apparently most restrictive RE: Pipercross or K&N - Toms306 - 29-06-2015 (29-06-2015, 11:52 AM)RetroPug Wrote: To clarify: I've got a K&N open cone that sounds pretty good and I've found a PiperX one in a cupboard that I was wondering whether or not to bother trying it out. If foam does sound noticeably different or better I might give it go. Foam seems to sound 'throatier' than paper in my experience, presumably from higher flow...but that probably means worse filtration lol. RE: Pipercross or K&N - RetroPug - 29-06-2015 I suppose I should just stop being lazy and swap it over and compare the sounds.
