Oil sump - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Oil sump (/showthread.php?tid=30968) |
Oil sump - Steve1990 - 23-06-2015 Hi guys im getting round to changing the oil in my hdi and the sump is leaking slightly so im going to remove and seal it first cant seem to find anything on what sealer to use i know ally sumps dont use gaskets but what sealant should i use or what have you used thanks. RE: Oil sump - cully - 23-06-2015 http://www.halfords.com/motoring-travel/tools-diy/head-gasket-exhaust-repairs/loctite-quick-gasket-200ml RE: Oil sump - Frosty - 23-06-2015 I tend to use this stuff and its pretty decent http://www.ebay.co.uk/itm/DIRKO-ELRING-SUMP-SEALER-SEALANT-COMPOUND-VW-ZETEC-DURATEC-XFLOW-PINTO-XE-YB-K20-/261842744772?pt=LH_DefaultDomain_3&hash=item3cf70b35c4 RE: Oil sump - HDi--Power - 23-06-2015 Dirko is the job, best sealer on the planet
