XUD temperature problems - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: XUD temperature problems (/showthread.php?tid=30871) |
XUD temperature problems - jakkkey - 14-06-2015 new to the 306 scene I've bought a ph1 d turbo, my problem which I'm having is that when I'm driving around or idling the car will get hot or if I'm on the throttle it will creep up forcing me to granny it everywhere. is this a known problem as I've bled the system and still have no luck, i don't know much about these cars and am looking to keep this one
RE: XUD temperature problems - kentiiboii - 14-06-2015 Try replacing the thermostat, is I hammer mine it will go above 90c but the fan kicks in about 98c iirc and cools it down. RE: XUD temperature problems - jakkkey - 14-06-2015 changed the stat yesterday, forgot to put that RE: XUD temperature problems - vincent1 - 14-06-2015 maybe worth changing the water pump? whilst your at it do the cambelt and adjuster if they have not been done recently. RE: XUD temperature problems - jakkkey - 14-06-2015 it was fine when i drove it home when i first got it then just started to do it all of a sudden, belt has been changed recently too RE: XUD temperature problems - vincent1 - 14-06-2015 has the water pump been changed i see you say the belt has some times the impellar on the aterpump goes. RE: XUD temperature problems - Seb_Ryan - 14-06-2015 What state is the rad in? RE: XUD temperature problems - jakkkey - 14-06-2015 ill check the paperwork tomorrow & its a newish rad its in good condition id say RE: XUD temperature problems - ozpug - 23-06-2015 Are the radiator fans working properly? I didn't have any on my car for a while and it would behave in a similar way. |
