will this fit - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: will this fit (/showthread.php?tid=30510) |
will this fit - mattydturb - 19-05-2015 Any one know if this turbo pipe will fit a 306 hdi for fmic RE: will this fit - Poodle - 19-05-2015 Might do, try it and let us know. If you need to be right to get it all sorted quickly, i'd suggest picking up a 110 hdi pipe from a 406 or c5 anyway, which you can always sell on at what you bought it for if it turns out you don't need it. RE: will this fit - pro_steve - 19-05-2015 I just bought two of these to find out they don't fit. Not sure if the compressor housing is rotated round on the 110? Instead I just made my own pipe work and ran it around the side of the sump and through the gap. RE: will this fit - mattydturb - 19-05-2015 What size pipes and joiners did you use steve n atm I'm using the normal turbo pipe but as I'm putting a new turbo on was gona do it the less restrictive and proper way here's a pic of the reconditioned turbo aswell RE: will this fit - toseland - 19-05-2015 If you get the C5 pipe (long, curved one) you will need a long tailed 41mm 90degree bend RE: will this fit - mattydturb - 19-05-2015 Been searching ebay n can't find 406 or c5 bottom pipe but I've come across this one its off a 2.2 c8 anyone think this will fit with a 41mm 90bend |
