What have you got left to do.. - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: What have you got left to do.. (/showthread.php?tid=30450) |
What have you got left to do.. - ginge191 - 12-05-2015 In tradition; the, "What have you got left to do" before the next big show (FCS/Pugfest) I'll get the ball rolling: 1) New tyres all round 2) DD headunit to find, buy and install 3) Remap to 255/265 4) De-tar/De-sap , wax, minor detailing to paintwork RE: What have you got left to do.. - Mattcheese31 - 12-05-2015 Everything and nothing........whatever I get time to do lol, car should get me there as is
RE: What have you got left to do.. - Eeyore - 12-05-2015 Jesus christ.... New battery Replace Heater Matrix Fit Refurbished GTI Rear Beam Fit Rear GTI6 ARB Fit Solid Rear Beam Mounts Fit Baker BM Engine Mounts Fit Wrapped GTI6 Exhaust manifold, magnex decat and magnex exhaust. Fit Seam Welded Subrframe (remove from estate) Fit Meyle HD Wishbones (remove from estate) Fit Lower Strut Brace FIT GTI6 ARB Fit GTI6 Sump ReFit Shortshift Full Service Refurbish Fondmetal 4000s Fit Spoiler Send Coilovers off for machining or fit standard top mounts again. Braided Brake Lines Paint plastic trims Paint Beam yeh... I think I win... If anyone is building an entire 306 from scratch then I must be second... RE: What have you got left to do.. - Niall - 12-05-2015 Fit air box and pipe up Paint some engine bay shiny bits clean moss off of car where it has stood so long Fit new splitter detail and wax car Have wheels refurbished after someone kerbed one
RE: What have you got left to do.. - Piggy - 12-05-2015 1) cut and fit all the polycarb windows. 2) fit and trim and "wrap" fibreglass bonnet 3) fit and check clearance for track wheels 4) wheel alignment 5) build new exhaust. 6) fit new exhaust 7) build new manifold 8) fit new manifold 9) fit new turbo 10) fit some ninja fueling mods 11) see "10" fail and try something else 12) retune Arduino...a lot. 13) test and setup brake bias 14) finish brake lines and clasps 15) fit and pipe in EMP gauge 16) fault find and fix EGT gauge 17) flock final parts and fit 18) paint damaged parts 19) fit frenchyness 20) adjust suspension again 21) finish strut brace, fit 22) build harness bar and fit 23) CLEAN a lot 24) tidy engine bay 25) polish all the metal parts 26) polish all the outside bits 27) secure battery 29) service 30) fit new driveshaft seals 31) fit new breather pipework 32) secure new air filter 33) fit oil cooler 34) remove oil cooler after the oil line explodes .... I'll add more when I remember it! RE: What have you got left to do.. - toseland - 12-05-2015 new turbo remap stage2+ win RE: What have you got left to do.. - Mattcheese31 - 12-05-2015 I'll make her shine like a diamond in a goats ass inside and out but other than that life's keeping me too busy for big bines and such tings
RE: What have you got left to do.. - zx_volcane - 12-05-2015 as always, try not to kill it RE: What have you got left to do.. - lolsteve - 12-05-2015 Fit sportscat/decat or coat current system in paste Fit coilovers fit grooved brakes fix squealing noise make rear strut brace deep clean RE: What have you got left to do.. - impotentials - 12-05-2015 Tax. insure mot fit oil cooler clean exterior polish engine oil change re paint a few bits and bobs RE: What have you got left to do.. - Dum-Dum - 12-05-2015 NSR tyre, 3 brake pipes, lots of cleaning, un tint NSF window, peg in boot carpet, lots of bits to tidy up with some fresh paint, new plates and re build the front end as it's getting some shinyness. RE: What have you got left to do.. - Pompey306mark - 13-05-2015 Roll up in my borrowed clio as there is no hope my car will be finished in time, if I find the time to come to either show. RE: What have you got left to do.. - bashbarnard - 13-05-2015 Tape up a bit of wiring. Cleaning. I was prepared. Helping SRowell with his 1.8. RE: What have you got left to do.. - 7057sam - 13-05-2015 Get bash to weld up my exhaust,job done
RE: What have you got left to do.. - adam b - 13-05-2015 Fix brake wobble with new bearing/hub Fit oil cooler Might around to wrapping the car. Had the material for ages now! Not doing fcs, next event is combe sprint 13/06 followed by track day there on 19th. Bought Pugfest tickets
RE: What have you got left to do.. - Nathan1305 - 13-05-2015 Try not to sell it and get an estate.... RE: What have you got left to do.. - ozonehostile - 14-05-2015 Fit hybrid rear arb paint inner wings and slam panel refit new radiator gut all the remaining aircon pipes and fit rallye aux belt setup fit large pile of powdercoated engine parts and brackets fit EPAS setup stud conversion for the new wheels refit front bumper with extra bracing for the underside fit slimline fans and oil cooler braided fuel lines weld blowing exhaust midbox suspension regrease and spanner check full deep clean inside and out to remove 6 months worth of dust RE: What have you got left to do.. - cully - 14-05-2015 wash, polish, nut and bolt check, Load and roll RE: What have you got left to do.. - kentiiboii - 14-05-2015 Tax Mot Gut the interior Fit bucket seats Fit harness Sort exhaust properly Make a Decat Finish filling, sanding and painting the rear dent. Fit quick shift Fit baker bm linkages Fit fiberglass bonnet Fit aero catches (bonnet and boot) 2 new tyres Fit rear bumper Paint and fit Solid rear beam mounts Paint calipers Paint wheels Buy side skirts Change oil Remove sunroof Hopefully fit my vibra technic lower mount instead of powerflex mount. Wash Wax Hope for the best. RE: What have you got left to do.. - mr_fish - 14-05-2015 Fit engine and deal with all associated issues. RE: What have you got left to do.. - 306Dan - 14-05-2015 Build the lot, looks like I'll be coming in the workhorse if I can get the time off RE: What have you got left to do.. - silverzx - 14-05-2015 Turn up. RE: What have you got left to do.. - RetroPug - 14-05-2015 This is before Pugfest: Track Rod Ends Droplinks Refit a few bits on the underside eg. spare wheel, heatshields Remove cat, get welded and refit cat & exhaust Discs and Pads all round Flush brake fluid Remove side light bulb from inside headlight ![]() Drive to settle new suspension and bed in brakes Very good clean Probably refit headunit that I took out to go in the daily Still a load more things to sort out but that's the realistic list for before then, given that I usually don't have weekends free and maybe 1 evening a week if I'm lucky, plus the odd 1-3 hours over a weekend. Will hopefully have a weekend or two in June though! RE: What have you got left to do.. - 6waysforward - 14-05-2015 Fit engine Fit intercooler Fit oil cooler x2 Wire and plumb it all back in Fit and wire swirl pot and bosch 044 pump Clean the car Mot Tax Get breakdown cover Actually make it to pugfest
