Hose sizes - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Hose sizes (/showthread.php?tid=3000) |
Hose sizes - cwspellowe - 24-04-2012 Evening fellas, does someone fancy letting me know the common hose sizes in the engine bay? ie. fuel lines, boost compensator etc? Thinking of buying new and cutting to length rather than hunting for standard used ones. Re: Hose sizes - ginge191 - 24-04-2012 For the life of me i can't remember the size, but know buying from ebay, altogether it cost me about £10. the return line's is the only different size you need. compensator and filter hose are the same iirc Re: Hose sizes - cwspellowe - 24-04-2012 Think it's about 10mm, and fuel lines are about 8mm? Re: Hose sizes - Ruan - 24-04-2012 6-8mm... If you buy silicon pipes you can make it all fit, I've got 6mm everywhere and it fits, you might just have to use a bit of lube to get it over some stuff... Re: Hose sizes - cwspellowe - 25-04-2012 If I went for 8mm all round it should clamp to the smaller stuff ok, right? Also the vacuum hose from pump to servo, 10mm? Re: Hose sizes - Ruan - 25-04-2012 Aye yeah. I think vac pump to servo is 10mm aye. Re: Hose sizes - ginge191 - 25-04-2012 Fuel hose from filter to pump - http://www.ebay.co.uk/itm/8mm-5-16-R6-F ... 1e60432d8b and leak off piping - http://www.ebay.co.uk/itm/DIESEL-LEAK-S ... 564688ab7c found it.. Also posted in project thread. This was what I bought, was enough plus spares |
