More power - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: More power (/showthread.php?tid=29973) |
More power - Moonwalker - 05-04-2015 Hi guys, There's probably been hundreds of posts on here about this, but here goes. I've got some spare cash going, (around £850) Could I modify any part of my engine to gain more power on this amount of money? And if so what could I do? All comments welcome as always.
RE: More power - Toms306 - 05-04-2015 Could buy another '6 for that, strap them together, instant 343bhp...
RE: More power - Moonwalker - 05-04-2015 (05-04-2015, 05:40 PM)Toms306 Wrote: Could buy another '6 for that, strap them together, instant 343bhp... Haha! Good shout mate! ![]() I am on the lookout for another one I'm gonna garage for the winter. But I fancy getting a wee bit more power out of my Phase 2!
RE: More power - 7057sam - 05-04-2015 Set catcams from pug1off the same as mine for £400 ish I think Mine have been dyno'd at 193 bhp and have 267 of duration the biggest you can go before you have to start messing about with internals RE: More power - Moonwalker - 05-04-2015 (05-04-2015, 06:51 PM)7057sam Wrote: Set catcams from pug1off the same as mine for £400 ish I think How easy are these to put into the engine? Do you need to remove the engine and re-time it etc? RE: More power - miles - 05-04-2015 Cambelt off and replace, cam carriers out, reseal and fit cams, Time them in, as for being easy it depends on what you know, I supply CAT Cams as well RE: More power - 7057sam - 05-04-2015 Mine are these,I believe they require you need to retard by 3 degrees [attachment=22517] RE: More power - Moonwalker - 06-04-2015 (05-04-2015, 10:21 PM)miles Wrote: Cambelt off and replace, cam carriers out, reseal and fit cams, Time them in, as for being easy it depends on what you know, I supply CAT Cams as well Are these the cams 7057Sam has? RE: More power - adam b - 06-04-2015 Be VERY careful putting cams into the RS engine. Especially if it has had any kind of rebuild including a head skim. http://www.306gti6.com/forum/showthread.php?id=104146 See post number 90, page 4 Best way to make your car quicker for that money would be lighter wheels and tyres. And a diff - just night and day difference to how much speed you can carry. RE: More power - Moonwalker - 06-04-2015 (06-04-2015, 07:33 PM)adam b Wrote: Be VERY careful putting cams into the RS engine. Especially if it has had any kind of rebuild including a head skim. Thanks for the advice, I will get that done, I'm getting a full exhaust system and new manifold fitted at Peugeot Eccosse as well, hopefully this helps her pull a little better.
RE: More power - adam b - 06-04-2015 Make sure the exhaust is lighter too
RE: More power - Moonwalker - 06-04-2015 (06-04-2015, 08:02 PM)adam b Wrote: Make sure the exhaust is lighter too It is, ![]() This is the one I'm thinking about? RE: More power - 7057sam - 06-04-2015 (06-04-2015, 07:33 PM)adam b Wrote: Be VERY careful putting cams into the RS engine. Especially if it has had any kind of rebuild including a head skim. Yeah scares me so much I'm actaully thinking of selling the cams and ecu to get a diff. Whatever power mine's running atm is absolutely fine for combe |
