Which fuel should you use? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: Which fuel should you use? (/showthread.php?tid=29785) |
Which fuel should you use? - Moonwalker - 20-03-2015 I seen on a manual that Peugeot recommend using e97 ron (super unleaded) fuel on a Gti 6, would this make the car run more efficient and run faster? All comments welcome as always!
RE: Which fuel should you use? - cully - 21-03-2015 i run Shell Vpower in mine and my 6 loves it, used to run momentum99 but wouldn't go back to that now RE: Which fuel should you use? - Poodle - 21-03-2015 From what i've seen they do love the premium. RE: Which fuel should you use? - Moonwalker - 21-03-2015 Thanks for the replies! ![]() Are all premium fuels the same quality? Or is Shell V Power the best out of them all? RE: Which fuel should you use? - RetroPug - 21-03-2015 I use 95. Have never noticed a change using premium. Might give it another go but doubt it will make a difference. RE: Which fuel should you use? - Moonwalker - 21-03-2015 (21-03-2015, 08:50 AM)RetroPug Wrote: I use 95. Have never noticed a change using premium. I'm planning on giving it a go too, I put some in her when I drove her up to Scotland from Preston, but I couldn't compare it to anything as it was the first time I had driven her! RE: Which fuel should you use? - welshpug - 21-03-2015 needs an ecu reset to make the most of it RE: Which fuel should you use? - lolsteve - 21-03-2015 these ecus are volatile memory then? Have heard conflicting views on petrol quality, some say its all from the same place others say Shell is the best and have their own refineries etc RE: Which fuel should you use? - welshpug - 21-03-2015 They go through a self learning process when re-set so if running lower octane fuel will bring the ignition timing back, however they don't take it back forwards. RE: Which fuel should you use? - adam b - 21-03-2015 Mine is happiest on esso 97. We see a big difference in the amount of ignition timing we can put into different fuels. RE: Which fuel should you use? - Piggy - 21-03-2015 My colt gti and ZX6r hated anything BUT Shell Vpower RE: Which fuel should you use? - Niall - 21-03-2015 Yeah the GTI6 loves a good 97-99ron fuel! Dont bother with the shitty tesco crap though. Before i went with my omex, i tried a few and V power was by far the best shortly followed by the BP one. RE: Which fuel should you use? - adam b - 21-03-2015 Momentum is consistently better for ignition timing than BP. Find that to be pretty equal with Esso and Texaco tbh, for all the marketing hype - around 25-30BHp on an otherwise standard GTR engine (bar a simple remap, itself worth at least 85BHp on an older car). Not far off V-Power at all. None of them are anything like what we can do with proper E85 or 105 race fuel - some serious gains to be had, but blinking expensive. We only ever quote on 99 V-Power, unlike a few tuners out there hehe... RE: Which fuel should you use? - Piggy - 21-03-2015 I thought v power was 97?? RE: Which fuel should you use? - adam b - 21-03-2015 Nah it's 99 RE: Which fuel should you use? - cully - 21-03-2015 copy from Wikipedia In the United Kingdom and Denmark (where Super Unleaded must be a minimum of 97 RON), V-Power has a rating of 99 RON (whereas V-Power's predecessor Shell Optimax was rated at 98 RON).[1] There is one other 99 RON fuel available in the UK, namely Tesco MOMENTUM99.[2] RE: Which fuel should you use? - Piggy - 21-03-2015 Ahhh it used to be 98 thats right |
