| The following warnings occurred: | |||||||||||||||
Warning [2] Undefined variable $unreadreports - Line: 31 - File: global.php(961) : eval()'d code PHP 8.3.32 (Linux)
injector feed pipes? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: injector feed pipes? (/showthread.php?tid=29730) |
injector feed pipes? - JTaylor2005 - 16-03-2015 Hey everyone. Im thinking of getting my injectors sent off to injectortune to get them cleaned and flow tested. I suppose I will need new injector pipes to replace the ones I remove. Also what do yu guys use to plug open fuel pipes? Thanks, Jack RE: injector feed pipes? - bashbarnard - 16-03-2015 Don't need new injector pipes unless they are properly worn. I've got some little plastic bungs I use to seal mine at work. RE: injector feed pipes? - JTaylor2005 - 16-03-2015 Okie dokie fair enough. Im kinda presuming that if I just line them back up well they should seat fine anyway RE: injector feed pipes? - bashbarnard - 16-03-2015 Yeah they will be fine. Hard to cock up injector pipes. |
