Heater - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: Heater (/showthread.php?tid=29439) |
Heater - Owen_G_ - 26-02-2015 My heater isnt the best in my 306. ive put a new water pump in and flushed the matrix. its not too bad now but ive been in others with a heater twice as good and way more blow force from the vents than my own. is this a case off maybe a blower pipe loose or a bad blower ? any ideas guys RE: Heater - mackat - 27-02-2015 new heater matrix?? RE: Heater - Owen_G_ - 28-02-2015 The matrix wouldn't cause the blower to loose any force through the vents. I think it may be a pipe behind the dash were it's loosening force, at a pipe joint or something RE: Heater - mackat - 28-02-2015 (28-02-2015, 12:54 PM)Owen_G_ Wrote: The matrix wouldn't cause the blower to loose any force through the vents. I think it may be a pipe behind the dash were it's loosening force, at a pipe joint or something Sorry - miss-read your first post.. too much coffee for the day?!? Contacts on the control knob? 1st 2 clicks down from full blast on mine don't do anything, then the 3rd click turns it down to the correct setting. If you're losing air in the pipes you should be able to feel it escaping somewhere it shouldn't. |
