What Phase Is This? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: What Phase Is This? (/showthread.php?tid=29259) |
What Phase Is This? - Gazcobain - 15-02-2015 My 306 has the circular fog lights, is fully colour-coded but does not seem to have the bolt-holes on the underside of the tailgate for connecting a spoiler. I've read that some Phase 3s were manufactured but can still have some Phase 2 parts. Any thoughts on this, folks? Cheers. RE: What Phase Is This? - hbomb1905 - 15-02-2015 It's a full Phase 3 but because of the spec it won't ever have had a spoiler. If you want one you'll need to drill holes or just bond one on with tiger seal or similar. RE: What Phase Is This? - welshpug - 15-02-2015 yup, phase3 base spec. RE: What Phase Is This? - Gazcobain - 15-02-2015 Ah right, I see. I thought they all had the holes on the inside regardless of whether they'd ever have had a spoiler or not. Much appreciated, folks. RE: What Phase Is This? - Toms306 - 17-02-2015 They do all have holes on the inside, covered with a black circular sticker, much higher than you expect from looking outside though so maybe you're not looking in the right place. RE: What Phase Is This? - PugRory - 17-02-2015 The spoiler I got from a scrappy had four 10mm nuts holding it on through the rear screen RE: What Phase Is This? - Toms306 - 17-02-2015 (17-02-2015, 10:43 AM)PugRory Wrote: The spoiler I got from a scrappy had four 10mm nuts holding it on through the rear screen That was an older spoiler from a ph1/2. Ph3 spoilers use two T20 bolts through the metal. RE: What Phase Is This? - MY95 - 17-02-2015 Defo full PH3 mate! Mines in the exact same colour! Mine looked the exact same until I added Ph2 rear spoiler, cyclones and debadged GLX side badges RE: What Phase Is This? - 7057sam - 18-02-2015 Slightly off topic When I was looking for a 6 I came across a late 1999 nile blue (phase 2 ) but it had Ph3 rub strips and Ph3 dials.I heard some did come out of the factory like that. RE: What Phase Is This? - Eeyore - 18-02-2015 (17-02-2015, 10:13 AM)Toms306 Wrote: They do all have holes on the inside, covered with a black circular sticker, much higher than you expect from looking outside though so maybe you're not looking in the right place. this! RE: What Phase Is This? - Gazcobain - 20-02-2015 Many thanks for all the replies, much appreciated. Would any soul be kind enough to post a picture of where the mounting holes should be? I simply cannot see them |
