HGOn the way out? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: HGOn the way out? (/showthread.php?tid=29183) |
HGOn the way out? - rtha6551 - 09-02-2015 Driving home earlier on, heaters blew ice cold as the temperature needle rose up to 90 and back down in the space of 10-15 seconds, before the heaters went warm and all was as normal Temp needle stayed at 70 for 10 or so miles then rose up to 80 when given a little pasting, has been normal since but people reporting HGF shortly after theirs done the same? Thanks RE: HGOn the way out? - Mattcheese31 - 10-02-2015 Has the coolant level dropped? Is the top pipe pressurising? Report back.. RE: HGOn the way out? - rtha6551 - 10-02-2015 (10-02-2015, 09:08 AM)Mattcheese31 Wrote: Has the coolant level dropped? Is the top pipe pressurising? Report back.. Will check coolant level when home Other night after a hard drive it was at 90 deg and the little hose coming out of the cap near the slam panel was pissing coolant out RE: HGOn the way out? - r3k1355 - 10-02-2015 Do sound head gasket like, the top hose will probably be rock solid - even when the car has been off for a while. My first DT died like that 4 years ago ![]() It limped along for 18 months tho which was alrite - had to top it up every morning to get to and from work
RE: HGOn the way out? - rtha6551 - 10-02-2015 (10-02-2015, 11:03 AM)r3k1355 Wrote: Do sound head gasket like, the top hose will probably be rock solid - even when the car has been off for a while. Which one is the top hose haha? Looks like I best put a 2L bottle in the car lol RE: HGOn the way out? - r3k1355 - 10-02-2015 The one connecting the top of the radiator to the thermostat housing on the engine. Big and thick, you can't miss it. RE: HGOn the way out? - Mattcheese31 - 10-02-2015 (10-02-2015, 11:01 AM)rtha6551 Wrote:99.9% the head gasket mate, may as well book it to get done now.(10-02-2015, 09:08 AM)Mattcheese31 Wrote: Has the coolant level dropped? Is the top pipe pressurising? Report back.. RE: HGOn the way out? - rtha6551 - 10-02-2015 (10-02-2015, 11:27 AM)Mattcheese31 Wrote:(10-02-2015, 11:01 AM)rtha6551 Wrote:99.9% the head gasket mate, may as well book it to get done now.(10-02-2015, 09:08 AM)Mattcheese31 Wrote: Has the coolant level dropped? Is the top pipe pressurising? Report back.. Coolant was low, filled it with water then went for a drive No problems, drove fine and when I got back (15 mile spirited drive) the top rad hose was soft Did drink all the water I put in, been told to take cap off start engine and fill with water till full? RE: HGOn the way out? - Mattcheese31 - 10-02-2015 You need to bleed it properly to know for sure, I'll explain if there's not a guide in the xud section. |
