How much Antifreeze/coolant - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: How much Antifreeze/coolant (/showthread.php?tid=29124) |
How much Antifreeze/coolant - Nathan1305 - 06-02-2015 So need to do a oil change and radiator flush on the DT how much antifreeze do I need to put in? I think I seen somewhere it takes 6.5L of coolant so is that 3.25L of water and 3.25L of antifreeze? Edit: just seen an XUD takes 9 litres of coolant! So 4.5L antifreeze 4.5L water? RE: How much Antifreeze/coolant - bashbarnard - 07-02-2015 50\50s in mine. Been fine for my ownership RE: How much Antifreeze/coolant - Piggy - 07-02-2015 Ive never gone that strong. 3 litres of longlife red for me, rest with pure water. RE: How much Antifreeze/coolant - Toms306 - 07-02-2015 Depends what it says on the bottle... Halfords stuff is 50/50 iirc. RE: How much Antifreeze/coolant - sweeney1987 - 07-02-2015 i just nick the ready mixed stuff from work
RE: How much Antifreeze/coolant - Nathan1305 - 07-02-2015 I got the Triple QX ready mix antifreeze/coolant so I'll do around 3L Coolant and the rest water and see how that goes
RE: How much Antifreeze/coolant - Toms306 - 07-02-2015 If its ready mixed you don't add water to it... RE: How much Antifreeze/coolant - ConorTRG - 07-02-2015 Coolant is ready mixed, use straight out of the drum. Antifreeze needs mixed with water. RE: How much Antifreeze/coolant - Nathan1305 - 07-02-2015 [attachment=21590] Got this today to hopefully get the 306 in a better state. So if I don't add water does it mean I have to buy another 5 litre bottle of coolant or will it be okay for a while on 5 litres of coolant RE: How much Antifreeze/coolant - Seb_Ryan - 07-02-2015 Its ready mixxed so dont add water.. RE: How much Antifreeze/coolant - Toms306 - 07-02-2015 You'll need to buy some more, it won't be ok on 5 litres. RE: How much Antifreeze/coolant - Nathan1305 - 07-02-2015 Ah that's annoying I'll have to try get some more soon |
