gear box code - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: gear box code (/showthread.php?tid=28913) |
gear box code - wibbz - 25-01-2015 Can any 1 help me out I'm looking for a gear box code on my 306 1.6 RE: gear box code - Toms306 - 25-01-2015 It's an MA gearbox, if that's the code you're looking for? If not, there is a flat plate on the 'box, usually just below the clutch arm on the front, if you remove the corrosion the numbers are written on there. RE: gear box code - wibbz - 25-01-2015 Cheers mate think it is ma box but need a code been told so I can get the right box RE: gear box code - Toms306 - 25-01-2015 The long code only proves the ratios afaik, any other MA box from the same era (106, saxo etc) will fit as well, its just that the ratios might be different. RE: gear box code - wibbz - 25-01-2015 Ok mate cheers do I just need to make sure it's tripple linkage RE: gear box code - Toms306 - 25-01-2015 Yeah does need to be triple linkage if yours is. The top linkage can be different, angled at 90 degrees instead of straight, but you can just buy a different link rod anyway. RE: gear box code - wibbz - 25-01-2015 Cheers for help guys Would 1 out of a 206 fit RE: gear box code - Toms306 - 25-01-2015 The 206 uses a hydraulic clutch on at least some engines so the 'box wouldn't be compatible. I don't know if they all used a hydro clutch though. RE: gear box code - wibbz - 25-01-2015 Ok mate I will look at it |
