URGENT!! HELP!!!!!!!! - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: URGENT!! HELP!!!!!!!! (/showthread.php?tid=28904) |
URGENT!! HELP!!!!!!!! - philpemberton94 - 24-01-2015 Slight issue in that my key wont go past position one in the ignition and i am stuck and hour away from home with no tools exept a couple of screwdrivers, a 13 mm socket and a 10 mm spanner, is there ANY way at all i can get it started? Its a 1999 1.9td with a lucas pump Cheers!! RE: URGENT!! HELP!!!!!!!! - Toms306 - 24-01-2015 Is the steering lock on? RE: URGENT!! HELP!!!!!!!! - bashbarnard - 24-01-2015 Yes you cam get it started. But it would involve basically stealling your own car in a sense. RE: URGENT!! HELP!!!!!!!! - philpemberton94 - 24-01-2015 No steering lock is off, how would one go about stealing their own car? RE: URGENT!! HELP!!!!!!!! - Toms306 - 24-01-2015 XUDis easy to start...you'll have to get past the immob with a Lucas though! RE: URGENT!! HELP!!!!!!!! - philpemberton94 - 24-01-2015 So how would i do that? RE: URGENT!! HELP!!!!!!!! - Toms306 - 24-01-2015 I don't know lol, if I did I'd have a driveway full of XUDs. ![]() Once the immob is off just bump start it as you can get to ignition. RE: URGENT!! HELP!!!!!!!! - pioneer DJ paddy - 24-01-2015 U could put a hot wire to the pump and then just cross the starter to get u home but no doubt ur pump still has the antitamer around the solinod so only other way out is pull the plastic off around the collum and get joining wires lol unless anyone else's cums up with sumthing :-) hopefully this helps RE: URGENT!! HELP!!!!!!!! - philpemberton94 - 24-01-2015 Managed to get it started with the key somehow, cheers for the help! RE: URGENT!! HELP!!!!!!!! - Piggy - 24-01-2015 Get some oil in that key barrel! |
