1.8 xs overheating - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: 1.8 xs overheating (/showthread.php?tid=28725) |
1.8 xs overheating - jjenn20 - 13-01-2015 1.8 xs overheating in traffic, any thoughts guys ?? RE: 1.8 xs overheating - Eeyore - 13-01-2015 Are the fans coming on? is there enough water in the system? are you losing water? right amount of oil? Mine used to overheat but that was with no fans and after a while waiting in traffic at the dartford crossing. Temporary solution... put the windows down and put the inside heater on max! If youre not going anywhere then turn the engine off. If you do start moving best to leave it in first for a while to make sure you circulate the water so you dont get any hot spots. RE: 1.8 xs overheating - jjenn20 - 13-01-2015 Yeh its got water/coolant and oils halfway up the dipstick, I dont think the fans kik in it runs at 80 degree when driving Whats the best tyres for cyclones RE: 1.8 xs overheating - Eeyore - 13-01-2015 (13-01-2015, 08:39 PM)jjenn20 Wrote: Yeh its got water/coolant and oils halfway up the dipstick, I dont think the fans kik in it runs at 80 degree when driving wait... halfway between max and min? or literally half way up the entire stick? 80 degrees is nothing when driving... if its over 100 then start worrying and turning the heater fans on max... Best tyres for cyclones? R888s Medium Compounds. RE: 1.8 xs overheating - jjenn20 - 13-01-2015 Half way between max n min, and yeh I have to turn heaters on when im in traffic, what profile tho RE: 1.8 xs overheating - Eeyore - 13-01-2015 er... 55 is normal profile... 50 is cheaper and looks better when lowered. RE: 1.8 xs overheating - jjenn20 - 13-01-2015 Sweet gona get a referb n spray with new tyres RE: 1.8 xs overheating - Ash J - 14-01-2015 R888s overkill on an XS. RE: 1.8 xs overheating - John1.4 - 14-01-2015 coolant looking rusty? might have a load of crap in the rad, maybe worth a good flush out and replace with some good coolant RE: 1.8 xs overheating - PUGNUT_XS - 23-01-2015 take the fan switch connector off and bridge it, if the fan comes on they you could have a shagged fan switch, thats the first port of call. |
