Whats this spare cut off lead? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Whats this spare cut off lead? (/showthread.php?tid=28684) |
Whats this spare cut off lead? - MY95 - 11-01-2015 [attachment=21082] RE: Whats this spare cut off lead? - Toms306 - 11-01-2015 Pic isn't the clearest, but the only wiring around there is ABS, which I doubt Rallyes have? Doesnt even appear to go anywhere!? It's not one of them static shock things people put on cars to reduce shocks is it? RE: Whats this spare cut off lead? - MY95 - 11-01-2015 Apologies, not sure what is is Rallyes have ABS yes Never heard of that shock thing before RE: Whats this spare cut off lead? - Piggy - 11-01-2015 Earth strap for the exhaust no? RE: Whats this spare cut off lead? - Toms306 - 11-01-2015 Why would you need to earth an exhaust? RE: Whats this spare cut off lead? - Niall - 11-01-2015 Difficult pic but i think your screwdriver is on the snapped exhaust earth strap. Ignore it tbh RE: Whats this spare cut off lead? - MY95 - 11-01-2015 Thanks all, worth cutting off then? RE: Whats this spare cut off lead? - swampy - 11-01-2015 (11-01-2015, 05:14 PM)Toms306 Wrote: Why would you need to earth an exhaust? Most peugeots have it! At least when they leave the factory they do RE: Whats this spare cut off lead? - Dum-Dum - 11-01-2015 Yeah its the exhaust earth strap, they have one for the mid section too. RE: Whats this spare cut off lead? - MY95 - 11-01-2015 Is it even needed? RE: Whats this spare cut off lead? - 306carter - 11-01-2015 As said it's a ground strap. RE: Whats this spare cut off lead? - Dum-Dum - 11-01-2015 I've never had electrical problems with my exhaust without them. RE: Whats this spare cut off lead? - MY95 - 11-01-2015 Can anyone explain what it does/did do? Not clued up at all on electrical stuff like this RE: Whats this spare cut off lead? - Niall - 11-01-2015 They are there to earth the exhaust to the body which has just made me realise something. The exhaust has a very bad earth connection. Its held to the body on rubber mounts and its only contact with the engine is a poorly fitting wire metal ring. What sits on the exhaust that need could do with a clean earth for its reference voltage? RE: Whats this spare cut off lead? - Dum-Dum - 11-01-2015 ^^^ A very smart point, for better lambda readings perhaps? RE: Whats this spare cut off lead? - Niall - 11-01-2015 (11-01-2015, 10:31 PM)Dum-Dum Wrote: ^^^ A very smart point, for better lambda readings perhaps? It may improve reading. It could also be to stop electrical interference with the radio. Dont forget its like a 2.5m long bit of metal. It could act as an big ariel with any electrical noise from the engine RE: Whats this spare cut off lead? - Ruan - 12-01-2015 Yep, for the lambda sensor, very bad ground reference otherwise. Also the Lambda has a heater in it... RE: Whats this spare cut off lead? - Piggy - 12-01-2015 Flip me. I have been such a dumbass. I knew they have them, knew what it was immediately but tottaly forgot to put my earth on my exhaust and I am getting funny interference issues. I KNEW I made another short earth lead for a reason!! job for later... RE: Whats this spare cut off lead? - Toms306 - 12-01-2015 Ah that makes sense, didn't think about the lambda! Do the diesels have them aswell if its for interference? Don't think I've ever seen one on a 306! |
