Identify this pump - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Identify this pump (/showthread.php?tid=2850) |
Identify this pump - Eeyore - 17-04-2012 Easy question... Spotted this on a 406 hdi 110 today at the scrappers. Presume its one of the funny half ecu controlled ones? ![]() Re: Identify this pump - Dan! - 17-04-2012 Yep Identify this pump - Jake - 17-04-2012 Yep believe you're right, Won't work on your 1.8. Re: Identify this pump - Dan! - 17-04-2012 ![]() Re: Identify this pump - mark_airey - 17-04-2012 Your correct, not a scrap of use in one bit other than to ra*e for parts and the casing ![]() Re: Identify this pump - Eeyore - 17-04-2012 gdgd. Just checking I know what I see! ![]() ![]() Re: Identify this pump - Connor - 17-04-2012 You didn't see that on a 110hdi... That's an xud Re: Identify this pump - Eeyore - 17-04-2012 hmmm i think you may be right! I did see a 110hdi and this so with my exceedingly awesome derv knowledge i have to say that i wasnt thinking straight when i said it was on a 110 lol Re: Identify this pump - Ruan - 18-04-2012 Sadly the casing is even useless too! Got the advance piston actuator underneath... So yeah, 'kin useless. Re: Identify this pump - Mattcheese31 - 18-04-2012 LDA pin is fine though as i have one in mine and i think the gov cradle is the same so ok for a few bits . . ![]() Re: Identify this pump - Ruan - 18-04-2012 Yeah, parts inside are pretty much the same, few minor differences, but how it's controlled is different. |
