MAF goosed? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: MAF goosed? (/showthread.php?tid=28359) |
MAF goosed? - dirtyboost89 - 18-12-2014 my hdi feels down on power, so i unplugged my maf last night and went for a spin, it felt exactly the same as before i un plugged it, could somone please confirm its knacked so i can add a new maf to my ever growing list of parts, thanks chaps RE: MAF goosed? - Eeyore - 18-12-2014 Yeh sounds like it! If anything I think there was a bit of a performance increase when it was unplugged. Probably best to get another on there. Should be £5 or so from a scrappers. RE: MAF goosed? - Toms306 - 18-12-2014 Yep, sounds like your MAF has died completely and the ECU is just using generic figures rather than measured ones. If you have an oiled air filter, get rid of it or it'll kill the next MAF as well. RE: MAF goosed? - dirtyboost89 - 18-12-2014 im going to buy a brandnew original maf, and buy a std air box as it currently running a cone filter RE: MAF goosed? - Toms306 - 18-12-2014 Cone filter is fine if its not oiled. But original airbox will be best yeah. RE: MAF goosed? - dirtyboost89 - 18-12-2014 its bone dry mate RE: MAF goosed? - Poodle - 18-12-2014 Better to get the airbox on first, else you could find the new maf dies just as fast. I'd also recommend buying a new maf, you don't know that a scrapyard job isn't already knackered or well on it's way. Make sure you buy genuine too, siemens vdo, is available from most motor factors. I think i have a standard airbox kicking about somewhere, in fact... RE: MAF goosed? - dirtyboost89 - 18-12-2014 yes that is what i was going to do! abit of a random one but, how would i find out who my caliper are made by (lucas or bosch? RE: MAF goosed? - Midnightclub - 18-12-2014 It's normally written on the caliper, they could also be bendix iirc RE: MAF goosed? - Toms306 - 18-12-2014 They'll be Bosch 266s on a v plate HDi usually, best to check though, its written on there as said...to make it more complicated there are 2 pad shapes of Bosch 266s haha. What cone do you have then? If its ramair or piperx its probably not that causing issues. Things like k&n are sprayed with a fine oil that coats the MAF and ruins it. RE: MAF goosed? - dirtyboost89 - 18-12-2014 i will check tonight, thanks lads!!! and its a cheap rip speed type thing i think RE: MAF goosed? - pro_steve - 18-12-2014 Just to confirm, if nothing changes when you unplug it it is already running open circuit on default values. RE: MAF goosed? - dirtyboost89 - 18-12-2014 sorry if sound daft, does that mean its knackard? (im very new to hdis) RE: MAF goosed? - Toms306 - 18-12-2014 (18-12-2014, 04:40 PM)pro_steve Wrote: Just to confirm, if nothing changes when you unplug it it is already running open circuit on default values. Default! That's the word I couldn't think of and used generic instead. ![]() (18-12-2014, 04:42 PM)dirtyboost89 Wrote: sorry if sound daft, does that mean its knackard? (im very new to hdis) Yep. RE: MAF goosed? - dirtyboost89 - 18-12-2014 cheers mate RE: MAF goosed? - JTaylor2005 - 20-12-2014 A lot of the time a cheap knock of cone filter even when not oiled will cause problems with MAF's. They just filter the air a lot less than the standard paper style filters meaning light dust and dirt gets in and burns onto the MAF wire. Had the same problem on my corsa with an non oiled cone filter that I got for £10 just for the noise it made -_- |
