Ap Clutch - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: Ap Clutch (/showthread.php?tid=28316)
Ap Clutch - pugtk - 14-12-2014
I've just stripped my donor engine back, it has pretty good clutch.
Its an ap clutch, are these any good?
I will be modding the gov, lda pin on a bosch, and around 25 psi on t2
I was thinking of putting a new sachs clutch in, but if i can get away with it for a couple of months, when I have more money..haha
RE: Ap Clutch - Jimbo - 14-12-2014
Its a good make yes, but obviously the friction plate could be worn, and as pressure plates get older thw clamping force is reduced.
RE: Ap Clutch - pugtk - 15-12-2014
Does an ap hold a similar amount of torque as a sachs?
it looks fairly fresh, there was only 120,000 on the car, so it cant have that much mileage.
Does any one know how wide(mm) a new friction plate is?
(15-12-2014, 02:22 PM)pugtk Wrote: Does an ap hold a similar amount of torque as a sachs?
If I could get away with a release bearing for now Smile
RE: Ap Clutch - welshpug - 15-12-2014
it'll just be a stock clutch.
