What is the Bosch pump attached to the gearbox end to the cam - Printable Version
+--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10)
+--- Thread: What is the Bosch pump attached to the gearbox end to the cam (/showthread.php?tid=28229)
What is the Bosch pump attached to the gearbox end to the cam - Mr_Nuclear - 09-12-2014
As per the title, it's been removed and I need new oring seals.
RE: What is the Bosch pump attached to the gearbox end to the cam - pro_steve - 09-12-2014
Vacuum?
RE: What is the Bosch pump attached to the gearbox end to the cam - Ruan - 09-12-2014
Yes, it's the Vacuum pump, the seals can be gotten from Peugeot - have a look on ServiceBox for the part numbers Smile
