odd power delivery - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: odd power delivery (/showthread.php?tid=28138) |
odd power delivery - miles - 04-12-2014 Replaced the old 306 with a newer one and going thru the little issues it has but before I start throwing parts at it she has a odd problem which is getting better the more it's driven, Car is a 2002 3 plug ECU, the issue is sometimes when you stick you foot down the power delivery is lacking, which leads me thinking it could be the throttle switch, No engine light, CAT's OK and not blocked, Doesn't look gunked up, Other time's it goes as it should, no pattern just when it decides to play ball RE: odd power delivery - cully - 04-12-2014 egr valve sticking open/ gunged up or MAF sensor would be my options Maf can be check by unplugging it and running the car for a while and see if the fault apears again Egr valve id say blank it RE: odd power delivery - miles - 05-12-2014 MAF is fine, checked that, Got some EGR plate to blank it with so will give that a shot RE: odd power delivery - Poodle - 05-12-2014 Sounds a lot like tps failing, is it only at full throttle you get the problem? RE: odd power delivery - 306estate2.0HDi - 05-12-2014 Try the Air Mass Flow Sensor, mine had that problem it is just a guess for lacking power odd power delivery - Jtrigga - 05-12-2014 I have exactly the same problem, I've changed the maf and blanked and remove egr but the problem is still their. RE: odd power delivery - Paul_13 - 05-12-2014 When was the fuel filter changed? RE: odd power delivery - JTaylor2005 - 05-12-2014 Clogged filter on the lift pump in the fuel tank maybe? RE: odd power delivery - miles - 05-12-2014 It seems more electrical to me, as it can be like a switch with the power coming and it stays for a while then goes back to lacking power, Happens at any throttle opening No idea on Filters RE: odd power delivery - pro_steve - 05-12-2014 Bring it to me and I'll figure it out, I'm in Bristol, not sure how far that is for you to drive. RE: odd power delivery - miles - 05-12-2014 thanks for the offer But I'll have a play and see as I've got far too much work on to even find a spare hour, Bloody rattly old Derv's odd power delivery - Jtrigga - 07-12-2014 (05-12-2014, 11:21 PM)miles Wrote: thanks for the offer But I'll have a play and see as I've got far too much work on to even find a spare hour, Bloody rattly old Derv's Let me know how you get on mate I'm quite puzzled by mine. RE: odd power delivery - miles - 07-12-2014 Paul dropped off a MAF and TPS, so will check those and sort a couple of wires out and will keep the post updated RE: odd power delivery - HDi--Power - 08-12-2014 Check the air doser, they have a habit of disconnecting and staying shut severely limiting the airflow to the engine and then randomly popping open and everything is back to normal. RE: odd power delivery - DeeTurbo - 08-12-2014 (08-12-2014, 01:18 AM)HDi--Power Wrote: Check the air doser, they have a habit of disconnecting and staying shut severely limiting the airflow to the engine and then randomly popping open and everything is back to normal. Good shout that. I completely removed the butterfly and shaft on my girlfriend 206 as it's a bit of a restriction as you can see below. I removed it when I was blanking the EGR. RE: odd power delivery - Poodle - 08-12-2014 I'd ruled that out as we de-egr'd and de-airdosered lolsteve's old hdi and still had the issue. RE: odd power delivery - Paul_13 - 08-12-2014 Turned out to be a wiring problem RE: odd power delivery - DeeTurbo - 08-12-2014 Any idea what wire it was and was it a connector issue or a broken cable? RE: odd power delivery - Paul_13 - 08-12-2014 The previous owner had chopped wires and directly fed it to the ecu plug. Wearing a humongous cowboy hat RE: odd power delivery - Poodle - 08-12-2014 Which sensor/actuator was this? RE: odd power delivery - miles - 08-12-2014 The TPS plug, It goes without saying what allot of people disagree with Solder on wires is not good as it fractures over time but in this case I didn;t have much choice, I'll see if I can find a new plug and crimp it back as it should be |
