Pesky rock - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: General (https://www.306oc.co.uk/forum/forumdisplay.php?fid=6) +--- Forum: The Couch (https://www.306oc.co.uk/forum/forumdisplay.php?fid=7) +--- Thread: Pesky rock (/showthread.php?tid=27958) |
Pesky rock - C.A.R. - 27-11-2014 On my way to work this morning on the A602 just joining the A10 Dual Carriageway and halfway down the slip-road I come across a couple of big-ass rocks. positioning the car above the biggest one and braking hard I collided with another one, instantly wrecking my front passenger wheel and tyre The best was yet to come; fitting the spare wheel at the end of the slip-road with no hard shoulder. My car-sharing colleague put on a Hi-vis and took the little triangle 50 yards up the road. wheel changed in 6-7 minutes and drove straight to the garage - it was pulling badly to the left on the way So if anyone has a spare Cyclone and is local to Hertfordshire please let me know!! RE: Pesky rock - Norledge - 27-11-2014 Ah mann not good. Could be a lot worse, we had a customers 911 in, 168 miles on the clock, floor pan totally destroyed by a brick someone left in the road! RE: Pesky rock - r3k1355 - 27-11-2014 Damn, bet that sorta stuff falls off overloaded skips all the time. RE: Pesky rock - C.A.R. - 27-11-2014 Yep, massive it was, about the size of two house bricks. Knew instantly the tyre was toast, was amazed how the wheel now has a big ol' dent in it. Was quite impressed with how quick I got it all swapped over bearing in mind the conditions and that the spare wheel cradle is f*cked!! And yes, I did initially drive off with the cradle dragging along the ground! RE: Pesky rock - Eeyore - 27-11-2014 I hit debris too. Costing me £62 for a new michelin ps3 fitted. RE: Pesky rock - C.A.R. - 27-11-2014 That's not bad. I have Michelin PS2's on the front, so I'm not sure I'll even be able to find another one quickly that matches... RE: Pesky rock - procta - 27-11-2014 is the wheel not repairable car? if it is might be worth using it as a spare when you sort out a replacement wheel. RE: Pesky rock - Eeyore - 27-11-2014 (27-11-2014, 02:32 PM)C.A.R. Wrote: That's not bad. I have Michelin PS2's on the front, so I'm not sure I'll even be able to find another one quickly that matches... its not bad but its £62 more than I wanted to spend! RE: Pesky rock - Mattcheese31 - 27-11-2014 I've a spare cyclone if you're passing DN12 way anytime RE: Pesky rock - RetroPug - 27-11-2014 (27-11-2014, 02:36 PM)procta Wrote: is the wheel not repairable car? if it is might be worth using it as a spare when you sort out a replacement wheel. Cyclones are dirt cheap anyway. RE: Pesky rock - londondan86 - 27-11-2014 It'll likely be one of those silly situations where it will work out cheaper to get a complete set of cyclones than buying a single! Glad your ok though dude, could have been a lot worse! RE: Pesky rock - RetroPug - 27-11-2014 I'm sure someone on here could sell him one cheaply. RE: Pesky rock - Toms306 - 27-11-2014 Hmm, that's not good! I saw a massive lump of scrap metal fall out of a scrap container lorry over a bump last week. Fortunately fell towards the verge not towards me but I did wonder how often it happens!! |
