Actual oem quality brake parts - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Other Marques (https://www.306oc.co.uk/forum/forumdisplay.php?fid=38) +--- Forum: Technical (https://www.306oc.co.uk/forum/forumdisplay.php?fid=40) +--- Thread: Actual oem quality brake parts (/showthread.php?tid=27832) |
Actual oem quality brake parts - Tom - 18-11-2014 Does anyone know of a good oem quality disc brake and pad? The discs and pads on the audi are almost at the end of there service life and i want to put something decent on it but obviously cant stump up whatever Audi are charging
RE: Actual oem quality brake parts - jamiek_uk2000 - 18-11-2014 I've always used the Brembo standard range which I have found to be great. Even take a bit of track abuse OK RE: Actual oem quality brake parts - Toms306 - 18-11-2014 Got access to TPS? Should be cheaper than Audi there but still genuine. RE: Actual oem quality brake parts - Jonny81191 - 18-11-2014 Pagid from ecp are pretty good, allegedly identical to oem, and I've yet to see any evidence to suggest otherwise RE: Actual oem quality brake parts - Toms306 - 18-11-2014 Plus Pagid discs look pretty!
RE: Actual oem quality brake parts - bashbarnard - 19-11-2014 Trws get my vote anyday RE: Actual oem quality brake parts - Tom - 19-11-2014 Whats tps? Thanks for the advice so far guys )
RE: Actual oem quality brake parts - bashbarnard - 19-11-2014 Trade parts specialist. Its for the vag group. Sort of like a motor factors just for them. They also do budget stuff RE: Actual oem quality brake parts - Toms306 - 19-11-2014 As above, basically trade prices. You need to be in the trade though, or as I did, join a forum that gives access and discount to TPS.
RE: Actual oem quality brake parts - bashbarnard - 19-11-2014 Or just say your in the trade like I used to. I now use my work account RE: Actual oem quality brake parts - Tom - 19-11-2014 Hmm, says i have to contact my local vw dealer... |
