removing tyre valves - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Interior, Exterior, ICE (https://www.306oc.co.uk/forum/forumdisplay.php?fid=12) +--- Thread: removing tyre valves (/showthread.php?tid=2783) |
removing tyre valves - samass - 15-04-2012 got the tyres taken off my lasers and my spare the other day, but forgot to get the guy to take the valves out, want them out for painting, how do i go about it? cheears Re: removing tyre valves - Dan! - 15-04-2012 Pliers Re: removing tyre valves - samass - 15-04-2012 and pull/twist? removing tyre valves - Jonny b - 15-04-2012 Hacksaw the base off inside the rim and pull it out with a pair of pliers, they will fit new ones when you get the tyres on anyways Re: removing tyre valves - Connor - 15-04-2012 Are you replacing them? If so just cut the bottom off Re: removing tyre valves - KrisB - 15-04-2012 Cut off the base of it and then pull it out ![]() Re: removing tyre valves - samass - 15-04-2012 cool, yep replacing them, will hack away! cheers chaps ![]() Re: removing tyre valves - Dum-Dum - 15-04-2012 Sharp knife behind the back of it will do the job. Re: removing tyre valves - Toms306 - 15-04-2012 Knife is how you'd do it at a tyre shop, no need for hacksaw lol. Re: removing tyre valves - samass - 15-04-2012 Yep.knife worked. Chop then pull. Easy. Cheers chaps |
