gearbox fluid - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: gearbox fluid (/showthread.php?tid=27804) |
gearbox fluid - jayspug86 - 17-11-2014 hi guys wheres the plug to top gearbox fluid up? RE: gearbox fluid - Grant - 17-11-2014 Its on the top of the gearbox, normally brown plastic, with a white pressure release plug in it, however they are sometimes white, black or grey. As below ![]() RE: gearbox fluid - Seb_Ryan - 17-11-2014 Or you take the wheel off, undo a 19mm i think? On the side casing (the level plug) its towards the bulkhead, and fill up through that until the oil overflows abit RE: gearbox fluid - Frosty - 17-11-2014 (17-11-2014, 12:22 PM)Seb_Ryan Wrote: Or you take the wheel off, undo a 19mm i think? On the side casing (the level plug) its towards the bulkhead, and fill up through that until the oil overflows abit Thats the way i have always done them RE: gearbox fluid - JTaylor2005 - 17-11-2014 couple of quick questions as I have also decided to do my gearbox oil. I know it is 75w80 that I need but what is the best brand and best quality oil? Secondly do I need to replace the washers on the drain, level, and filler plugs when I remove and replace them? Thanks RE: gearbox fluid - Toms306 - 17-11-2014 Best oil is the genuine stuff tbh. 9730 AA part number off the top of my head after buying so much lol. As for the washers, I always forget and they often leak after lol. Also check your driveshaft oil seals, as you'd need to drop the oil again if one needs to be changed in a months time. RE: gearbox fluid - JTaylor2005 - 17-11-2014 I can't find the washers anywhere haha. Or are they just a standard size that loads of gearbox's have? RE: gearbox fluid - Toms306 - 17-11-2014 I think they're the same as engine sump plug washers. RE: gearbox fluid - JTaylor2005 - 17-11-2014 Okie dokie. Cheers mate ![]() ![]() RE: gearbox fluid - Pgtips - 17-11-2014 (17-11-2014, 09:57 PM)JTaylor2005 Wrote: couple of quick questions as I have also decided to do my gearbox oil. This is peugeot spec & probs cheaper than pug http://www.amazon.co.uk/Total-BV-Transmission-Manual-TOT-149980-2/dp/B008PS2OQ2 RE: gearbox fluid - Frosty - 18-11-2014 The washers for the gearbox im 99% sure are the same as the sump plug for the engine. Pretty sure 31327 is the part number, we stock them at work RE: gearbox fluid - Alan_M - 22-11-2014 https://www.nielsencdg.co.uk/acatalog/Total-Transmission-BV-75W80-Citroen-Peugeot-Gear-Box-Oil-4L-TOT_149980_4.html Can't remember what the postage is though, but that's where I get all my fluids from. Sump plug washers can gotten from Amazon as a job-lot (100+). RE: gearbox fluid - steve1001 - 22-11-2014 I normally get 3 or more goes out of a copper sump washer by backing it up with a bit of ptfe tape. The ptfe tape consolidates the joint. I carefully wrap ptfe tape over the washer and make a very neat job of it. I roll ptfe tape on my knee to make string. Then I wind a little on the sump plug thread, not over the whole thread, but around the thread immediately in front of the washer ie. make a ptfe ring. I ensure the joint surfaces are perfectly clean and never ever overtighten. Steve (saving you 50p) gearbox fluid - zx_volcane - 22-11-2014 You can anneal copper washers by heating then up with a blowtorch and reuse them plenty RE: gearbox fluid - Poodle - 22-11-2014 Any decent motor factors should be able to sell you sump bung washers for pennies. RE: gearbox fluid - jonas306 - 18-03-2015 I'm thinking to change the gearbox oil, is it recomended the TOTAL one, or any difference with the COMMA or Valvoline?And is it 2litres? RE: gearbox fluid - Poodle - 19-03-2015 It is two litres and i'd stick to the total stuff myself, used comma before and it was awful. |
