Tigerseal and the chances of removal - Printable Version
+--- Thread: Tigerseal and the chances of removal (/showthread.php?tid=27705)
Tigerseal and the chances of removal - rtha6551 - 10-11-2014
Hi all
Got a fibreglass spoiler tigersealed onto my boot lid and want to know if there is a way to remove it?
Doesn't matter if it takes the paint with it as I plan to get it sprayed again due to a bit of corrosion elsewhere
Assuming now I've said that the majority of responses wil be 'smash the f*ck out of it' Big Grin
Thanks
RE: Tigerseal and the chances of removal - r3k1355 - 10-11-2014
It's a polyurathane adhesive, so stuff like razor blades to cut through it.
I dunno if heating it up abit will make it more flexible, or just set it or the spoiler on fire.
RE: Tigerseal and the chances of removal - Toms306 - 10-11-2014
Cheese wire
RE: Tigerseal and the chances of removal - londondan86 - 10-11-2014
Plus one for cheese wire. The only way Tbh, you will spend ages hacking away with a Stanley and heat will help so use a heatgun to help getting started
