ABS sensor change - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Suspension, Transmission, Handling & Braking (https://www.306oc.co.uk/forum/forumdisplay.php?fid=19) +--- Thread: ABS sensor change (/showthread.php?tid=27571) |
ABS sensor change - welshhero - 03-11-2014 Hi everyone. Complete noob so apologies in advance. I have just changed the rear axle on my 306 1.9TD 1999. So when the axle turned up the previous **** has cut the ABS sensor leads rather than unplugging them. Removing the sensors from the old axle in one piece was not possible so I have had to buy new ones. These have now turned up however I cannot get them through the hole in the back plate of the drum. So was I supposed to completely remove the drums by getting the 4 * M8 bolts out or are there different diameter holes for different axles. Thanks All Welshhero RE: ABS sensor change - ConorTRG - 03-11-2014 Sand the hole in the trailing arm, and I also jad to sand a bit pf the sensor itself when I put ones in before, there a tight fit. RE: ABS sensor change - welshhero - 04-11-2014 Cheers Conor! Will give it a go today. |
