wtf is wrong now ( hopefully fixed, fingers crossed ) - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: wtf is wrong now ( hopefully fixed, fingers crossed ) (/showthread.php?tid=27544) |
wtf is wrong now ( hopefully fixed, fingers crossed ) - Matt - 02-11-2014 So went to start the car this morning after my massive cock up with the cambelt. Charged the battery up last night. Primed the grenade after connecting the battery back up. Turned the key. And it struggled to start. As expected, it had been sat for 4weeks. After about 10 seconds it fires to life. Runs for about 5 seconds. Which I can rev but the rev gauge doesn't move. After about 5 seconds it dies, will not start unless I prime the grenade. What have I done wrong lol RE: wtf is wrong now - Paul_13 - 02-11-2014 Sounds like vane pump is stuck or you've a massive Apr leak. Rev counter, you've probably disturbed the wiring. Or is died, mine died suddenly RE: wtf is wrong now - pioneer DJ paddy - 02-11-2014 Are u getting a good flow of fuel RE: wtf is wrong now - Chris_90 - 02-11-2014 Sounds like vane pump as said, prime grande start it and keep pumping it see it'll keep running / rev if so definitely vane pump had similar issues with many if my bosch pumps. Has the pump been stud with veg in? Or dry? RE: wtf is wrong now - Matt - 02-11-2014 It's been on the car the entire time. I've had literally nothing but problems since buying this pump. Ffs. How do I check the flow of fuel? Take it off the pump? RE: wtf is wrong now - darrenjlobb - 02-11-2014 Does it suck grenade in when it dies? Have you tried running it from a bottle of fuel to rule out a bad supply? If so, remove fuel return host (right hand side) from pump, prime until fuel starts to run out return pipe, then start it and run around and watch how much fuel spills from the return on idle...Report back. also, remove the fuel inlet pipe from pump, and pump grenade, does fuel pump up EASY from the tank? and quickly? If so, and not much fuel is coming out return (video / tell us) then sounds like vane pump. RE: wtf is wrong now - Matt - 02-11-2014 Well it just drove down the road. It took about a minute of turning over to start but it started. Turns out these cars like this thing called diesel... Somehow think I've knocked the wiring or something for the fuel gauge. It said 1/4 slapped somefuel in there and I'm now sat just in the red :/ no idea what happened to that. Drove up the road. Sounds okay. (by okay I mean as rattly as it was) types bit flat so makes the steering feel disconnected. And that made me paranoid. Back home and on the drive. Will use the air compressor at work to do the tires tomorrow and will report back to how she is. Got a little bit of a missing on idle :/ |
