GI: 205 5door XUD9TE with some trick bits - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: For Sale (https://www.306oc.co.uk/forum/forumdisplay.php?fid=26) +--- Forum: Cars (https://www.306oc.co.uk/forum/forumdisplay.php?fid=21) +--- Thread: GI: 205 5door XUD9TE with some trick bits (/showthread.php?tid=26864) |
GI: 205 5door XUD9TE with some trick bits - Paul_13 - 27-09-2014 I'll be putting up for sale my 205 soon as i'll be buying a HDI estate 205 GRD 5 Door (around 220k on the shell) There is virtually no rust on the car apart from the front headlamp panel near the radiator which can be repaired easily and the inside of one of the doors. The inner wings are showing the usual rust but nothing major to worry about. The spec list: Basically 1.9 GTI running gear all round, GTI front subframe/1.9 gti hubs/ 1.9 driveshafts/ 1.9 struts and springs 1.9 gti brakes ds2500 pads plenty of life left in them 1.9 gti torsion bars and arb in the rear beam, solid beam mounts, drum brakes. Beam was rebuilt by myself recently in the last 20k 1.6 gti wheels with nearly brand new tyres 309 gti solid front subframe mounts (instead of rubber) 309 gti wishbones to give negative camber Steering rack has new rack ends and track rod ends 309 goodwood full leather seats back and front. THE most comfortable seats I have owned STDT clocks which means there is a rev counter and coolant temp sensor GTI carpet/dash/clock surround Engine: Will be putting a 1.9 XUD engine in to replace my current engine. The engine has come out of a running car and shows all signs of being healthy. It will have a T2 turbo 9mm Bosch pump, gov modded 10mm fuel lines HDI gearbox STDT radiator which is twice as thick as a gti rad. The radiator is lowered ready to have a front mount plumbed in. The car will be sold with a top mount intercooler as I sold the front mount setup. Looking for £550 The car could be broke for a lot more than this but I don't have the space/time to do so The reason for selling is I need a larger car for work RE: GI: 205 5door XUD9TE with some trick bits - bashbarnard - 27-09-2014 Pics? Would love it see if I convince other half RE: GI: 205 5door XUD9TE with some trick bits - padge - 27-09-2014 test? and pics RE: GI: 205 5door XUD9TE with some trick bits - Paul_13 - 28-09-2014 I'll get pics shortly. What do you mean by test? That it actually starts? How the car looked with the IC fitted Brand new stdt rad that costs and arm and leg RE: GI: 205 5door XUD9TE with some trick bits - ginge191 - 28-09-2014 Very interested RE: GI: 205 5door XUD9TE with some trick bits - padge - 28-09-2014 As in MOT RE: GI: 205 5door XUD9TE with some trick bits - Mattcheese31 - 28-09-2014 that's pretty cool tbh . . RE: GI: 205 5door XUD9TE with some trick bits - Paul_13 - 28-09-2014 Sorry, it's Mot'd till March from memory. I'll keep you posted ginge |
