2.0 HDI Gearbox - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: 2.0 HDI Gearbox (/showthread.php?tid=26850) |
2.0 HDI Gearbox - shazilla - 26-09-2014 Guys, Hows it going?? I just went to changed my Gearbox oil on my 2.0 HDi, and found that the oil was like metalic silver paint. Starange init! Also there was only under a litre, where as autodata says it sould have 2l. Can someone please help as im confused. Thanks S. RE: 2.0 HDI Gearbox - Frosty - 26-09-2014 The oil may have not been changed for ages or even changed at all. As for only having about a litre in there could be down to the drive shaft seals leaking over time and the level not being checked RE: 2.0 HDI Gearbox - Piggy - 27-09-2014 Sounds like it had lots of metal bits in it and didnt have the 2litres it should have in it!?! RE: 2.0 HDI Gearbox - shazilla - 27-09-2014 Didnt spot any leaks, looking at history car has never had a oil change, drained 700ml, had a few metal bits init. RE: 2.0 HDI Gearbox - shazilla - 04-10-2014 Any ideas on how many kg the gearbox is? want to see if i can get a delivery via interparcel. RE: 2.0 HDI Gearbox - welshpug - 04-10-2014 around 37. |
