sump - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=17) +--- Thread: sump (/showthread.php?tid=26644) |
sump - cluskie - 14-09-2014 i need a new sump for my 1.8 16v...will a gti one fit? finding one for mine is like looking for rocking horse shit...whereas gti ones seem to be everywhere RE: sump - Frosty - 14-09-2014 I cant be 100% sure but i dont think a gti 1 will fit as its acts as part of the gearbox cover on the gti6. I think i may have a sump off a 1.8 still. I will check if your interested? RE: sump - miles - 14-09-2014 Any sump will fit, Even the old 205 GTi box's fit, just 2 bolt holes are not used which is extra on the RS engine anyway, the A/C pipes might be different is the only thing, RE: sump - Niall - 14-09-2014 The GTI sump is completely different but MAY fit. Will mean removing the shield from the bottom of the box on the 1.8 if it does fit. RE: sump - powerandtorque - 14-09-2014 The GTi sump will certainly bolt up and will use the same bolts, but the PAS pipe under the car will probably need a bit of tweaking as the brackets won't fit. I do have a mint 1.8 16v alloy sump in the garage though if you need one? RE: sump - cluskie - 15-09-2014 If you've got a sump from a 1.8 16v with the air con pump brackets ill buy that. Just need to get it fixed so I can sell the car. How much you looking for sump? You'll have to email me as I can't pm anymore. Josh.McCluskie@gmail.com RE: sump - cluskie - 17-09-2014 How much would you be after for the sump? RE: sump - powerandtorque - 17-09-2014 It's an alloy sump from an AC equipped 1.8 16v. Let me dig it out tonight to double check it and I'll be in touch. RE: sump - cluskie - 18-09-2014 Don't mean to nag but did you sort the sump? Really need to sort one RE: sump - cluskie - 22-09-2014 anyone got one for sale? RE: sump - 306gtiparts - 25-09-2014 (22-09-2014, 06:48 PM)cluskie Wrote: anyone got one for sale? Look on ebay buddy. RE: sump - cluskie - 26-09-2014 seen a few but not the 1.8 ones, and dont want to buy one that might not fit |
