what is this grey relay for? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: 306 Repairs & Mods (https://www.306oc.co.uk/forum/forumdisplay.php?fid=22) +--- Forum: Electrics (https://www.306oc.co.uk/forum/forumdisplay.php?fid=23) +--- Thread: what is this grey relay for? (/showthread.php?tid=26535) |
what is this grey relay for? - wacker315 - 07-09-2014 Hi all could anybody tell me what is this grey relay used for as mine is goosed. Thanks Its the only grey relay thats in the fuse box underneath the steering wheel. Thanks RE: what is this grey relay for? - Nunolinha - 07-09-2014 I can't see the picture :/ RE: what is this grey relay for? - Toms306 - 07-09-2014 Indicators/hazards if its on the top right. RE: what is this grey relay for? - wacker315 - 08-09-2014 Not sure how to add pictures sorry. Its the only grey relay box underneath the steering wheel that sits above the fuses. My front window fuse had blown and just put another 1 in and the windows still arent working and i am now puzzled? just wondered if that grey box had anything to do with the windows also? http://i147.photobucket.com/albums/r285/bcfczuluarmy/Phase3fusebox.jpg RE: what is this grey relay for? - wacker315 - 09-09-2014 Does anybody kmow? i am stumped as neither of my window motors even try and work when use either of the door switches. Thanks in advance RE: what is this grey relay for? - Toms306 - 09-09-2014 Yep, that's the indicator relay. Windows are one of the green ones but cant remember which now! Have you changed window switch at all? From manual to auto maybe? Or the door loom wiring is shorting and popping your fuse... RE: what is this grey relay for? - wacker315 - 10-09-2014 Thanks, no everything is standard since i have had the car. An update though. My electrics are now doing really weird things! i have changed the 30a fuse that the windows work from and still nothing. I cant even hear the motors trying to work. The car will now no longer lock as my key fob just suddenly stopped working, but now when i press the lock button the car locks but then opens again straight away..... RE: what is this grey relay for? - Toms306 - 10-09-2014 That's a common broken door loom issue... Peel back the rubber on the loom between the door and pillar and I'll bet more than one of the wires is broken or at least damaged in there. |
