Anyone de-airdoser'd their HDI? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Anyone de-airdoser'd their HDI? (/showthread.php?tid=26328) |
Anyone de-airdoser'd their HDI? - Tom85 - 27-08-2014 Has anyone removed the air doser from the late HDIs? I have a spare older inlet elbow without the air doser and was wondering if it was worth swapping to remove the air doser. Already have an EGR blank. Thanks RE: Anyone de-airdoser'd their HDI? - rryan - 28-08-2014 i removed my inlet elbow to fit my boost gauge take off and at the same time i removed the butterfly part of the air doser, but i havent notched any difference , so its probably not worth swapping over. (im not sure whether the non air doser inlet elbow flows better) it is worth cleaning the sooty crap out of one of them tho RE: Anyone de-airdoser'd their HDI? - Toms306 - 28-08-2014 Doubt it'll be noticeable on a standard/stage 1 but yes it will restrict flow a tiny bit. Its not doing much if you've disconnected the vac lines to it though. So basically, if you're removing it anyway to tap for a boost guage them may as well change it, if you wouldn't otherwise have been removing it then it's not worth the hassle... Anyone de-airdoser'd their HDI? - Tom85 - 28-08-2014 Cheers guys. The inlet gasket is leaking in the usual place so I might just swap it if I've got to take the old one off to swap the gasket and can clean it up.. Do they elbows come off easily in situ? The other one I took off an engine that was already out of the car. Thanks RE: Anyone de-airdoser'd their HDI? - cully - 28-08-2014 i couldn't get to the clips holding mine on so gave up i tapped the elbow in situ with the elbow unbolted from the manafold and stuffed with rag so i could stop swarf falling back into the turbo RE: Anyone de-airdoser'd their HDI? - Poodle - 28-08-2014 You can take it off in situ, but it's a royal bastard of a job. Anyone de-airdoser'd their HDI? - Tom85 - 28-08-2014 Hmm might just leave it be then.. Or wait until I have to take the engine out one day! Cheers |
