ecu replacement - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: TU Petrol Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=18) +--- Thread: ecu replacement (/showthread.php?tid=26079) |
ecu replacement - handsomejackuk - 21-08-2014 if i need to change the ECu on my car as suspect it may be blow, what else needs to be changed ? does it need a key reader, and the part behind the ecu ? RE: ecu replacement - Toms306 - 21-08-2014 You need to be sure of the problem before changing expensive parts like ECU's really. But you need the ECU, the immobiliser chip in the key and the immobiliser box as a matched set. Don't need the key reader as its just a reader, not coded. RE: ecu replacement - miles - 21-08-2014 Look at http://www.bluestreak.co.uk/home/ they can test/repair it at a fair price RE: ecu replacement - Grant - 21-08-2014 What symptoms do you have that lead you to believe the ECU has spiked? |
