HG failure? - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: HG failure? (/showthread.php?tid=25854) |
HG failure? - Nathan1305 - 10-08-2014 Found this lovely brown grease type stuff on the water cap, should I worry or is it just how XUD's are? [attachment=18313] RE: HG failure? - 1616six - 10-08-2014 It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm? RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 07:33 PM)JJ0063 Wrote: It's a sign, but not necessarily HG failure. Any other symptoms? Using water? Running warm? No it's been perfect. Just checked on the off chance and noticed it, anything I can do to help it? RE: HG failure? - Danny2009 - 10-08-2014 I have never seen sludge on any xud I've witnessed with hgf Oil cooler may have shit itself and leaking oil into the coolant RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 07:46 PM)Danny2009 Wrote: I have never seen sludge on any xud I've witnessed with hgf Shit, can this be fixed? RE: HG failure? - Toms306 - 10-08-2014 It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol. RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 07:55 PM)Toms306 Wrote: It's usually pressurising pipes on Pug engines (XUD and TU at least!) that indicates HGF. So I would agree with Danny and say it's not. The oil cooler is easy to change if it is that, it's underneath the oil filter but you do need a massive socket to remove the bolt from it lol. :/ hope it fixes it, is it safe to drive like this? RE: HG failure? - Danny2009 - 10-08-2014 I'd wipe the cap put it back on and carry on like nothing's changed Just keep a eye on the temp gauge a quick glance over now and again Wouldn't worry me tbh RE: HG failure? - Toms306 - 10-08-2014 Personally I'd flush out the coolant system and see if it returns... Yeah it's safe to drive as long as you keep an eye on it. RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 07:59 PM)Danny2009 Wrote: I'd wipe the cap put it back on and carry on like nothing's changed (10-08-2014, 08:00 PM)Toms306 Wrote: Personally I'd flush out the coolant system and see if it returns... That's good news then ![]() RE: HG failure? - Stevo-trendy - 10-08-2014 Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 08:09 PM)Stevo-trendy Wrote: Do you do a lot of short trips in the car ? Stop start to the shops & back could just be condensation build if the engine isn't getting upto full temp Yeah I work 10 minutes away, should I drive a little longer? RE: HG failure? - Stevo-trendy - 10-08-2014 Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out RE: HG failure? - Nathan1305 - 10-08-2014 (10-08-2014, 08:55 PM)Stevo-trendy Wrote: Ye take it out for a long run let the engine come upto temp , a few blasts down a bypass or a good run on the motorway should clear it out Sweet ill have to do that |
