first things to do to a hdi - Printable Version +- 306oc - Peugeot 306 Owners Club & Forum (https://www.306oc.co.uk/forum) +-- Forum: Engines (https://www.306oc.co.uk/forum/forumdisplay.php?fid=16) +--- Forum: DW10 HDi section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: first things to do to a hdi (/showthread.php?tid=25781) |
first things to do to a hdi - binty306 - 06-08-2014 hi there whats the best mods (cheap as possible) for my 306 hdi estate just want to make it run a bit better with abit more power any advise would be great cheers RE: first things to do to a hdi - Danny2009 - 06-08-2014 Service, maybe with a k&n panel filter Decat exhaust Remap In that order IMO Don't bother with cone filters if there oiled they f*ck the maf up and don't make any more power RE: first things to do to a hdi - binty306 - 06-08-2014 where is the best to get a remap am from middlesbrough RE: first things to do to a hdi - underground375 - 06-08-2014 blank off the egr top left of the engine bay RE: first things to do to a hdi - Poodle - 07-08-2014 Don't bother with uprated panel filters either imo, they're just as bad as cone filters for the most part when it comes to poor filtration/flow and killing the mafs, K&N are as bad as the rest. A standard panel filter in the standard airbox will flow more air than you will ever need this side of 180bhp. Bear in mind a decat could be considered an mot failure since they revised they mot rules recently, the regs have been tightened up specifically on diesel exhaust systems, so worth putting a fake cat on. Could also do a midbox to backbox conversion. There's a few guides in the guide section that cover this pretty comprehensively, worth a look.
RE: first things to do to a hdi - pro_steve - 07-08-2014 Service, de-cat, EGR blank, then remap with EGR delete. If it's particularly slow you might have a problem with the MAF, but if all is good then you can go straight for the remap. There are a few companies who can offer good remaps for the HDI engines, all you need is an MPPS tool and then you can buy the remap via internet and upload it yourself. No need to travel around and you can get a good quality map. Steve RE: first things to do to a hdi - binty306 - 07-08-2014 where can i get one of the mpps tools and what are they cheers RE: first things to do to a hdi - pro_steve - 07-08-2014 Take a look on eBay, its a device that programs the ECU through the diagnostics port. All you need is a laptop. There's a guide on my website under downloads. |
