vnt turbo? - Printable Version
+--- Forum: XUD Section (https://www.306oc.co.uk/forum/forumdisplay.php?fid=11)
+--- Thread: vnt turbo? (/showthread.php?tid=25422)
vnt turbo? - craigyt - 22-07-2014
Sorry for askin the same old question but im in need of advice!
Im stickin a 1.9 dci into my1.5 megane, its the 130 spec with gt1749v turbo.
Now, im looking at 200bhp but unsure if this turbo can take it, and seeing as though you guys run 1.9 engines its pretty similar!
Darksidedevelopments use a gtb1749v to reach 200bhp on the 1.9 8v but whats the difference from a gt to a gtb?
Would a gt1852v from a 2.2 be a better option? I will be retaining the ecu vac can control aswel.
Any other options i can look at?
Cheers
Craig
RE: vnt turbo? - Toms306 - 22-07-2014
I don't see how a PSA XUD is in anyway similar to a Renault DCi...except the capacity lol.
As for the turbo though, they use a 1749v on 1.9PD's which can push 200bhp, and the same with Vaux 1.9CDTi's which can make over 200bhp...
RE: vnt turbo? - craigyt - 22-07-2014
(22-07-2014, 08:58 AM)Toms306 Wrote: I don't see how a PSA XUD is in anyway similar to a Renault DCi...except the capacity lol.
Exactly that, same displacement, so would be similar in exhaust gas volume and air in. And as there is a few turbo guys ie ruan, darren and james to name a few i was looking at what would be best suited to this size engine
RE: vnt turbo? - Dum-Dum - 22-07-2014
I think the 49 will be right at its limit at 200bhp. You might actually make the power easier with the 1852.
The Garrett turbo series started as GT then went to GTA and are now on the GTB series (actually I'm sure I've seen GTC stuff but its out of our price range) anyway the more modern stuff tends to be more efficient and less laggy. Any VNT turbo is likely to be a GTA even if it doesn't say so on it.
RE: vnt turbo? - jammapic - 22-07-2014
Craig, just go bigger turbo. Will make the power MUCH easier, less heat, less stress etc etc.
JP
RE: vnt turbo? - Piggy - 22-07-2014
GTB is a big leap on from GTs
RE: vnt turbo? - Ruan - 22-07-2014
GTB1749s are all well and good and yes they will make 200hp... No point in spending money on putting one in for really pushing it...
On a 1.9 8v Commonrail I'd be looking at something like a GTB1756VK or GTB2056VK - the 1756 will make 230hp, the 2056 will make 260 or so.
RE: vnt turbo? - craigyt - 24-07-2014
Got the engine sat in the garage now, just waitin on the turbo, rs tuning say 170-180bhp is max on this turbo, so what do we reckon, hybrid to make a gt1752v or just go gt1852v? What would be the difference between the hybrid 17 to the 18?
